C# calling Fortran
kstultz
I'm working on a project where a C# GUI is being used to call a Fortran dll. Everything worked fine until I upgraded VS2005 with SP1. Now C# won't call my dll anymore. I get an error message that says: "An attempt was made to load a program with an incorrect format (Exception from HRESULT: 0x8007000B).....". On machines that have not been upgraded, the code works fine.
Have there been any other similar problems reported and dones anyone have an idea of what I should doother than try touninstall SP1?
Thanks, Kenny
I just tried my C#-calls-Fortran example with VS2005 SP1 and Intel Fortran and it worked ok. I know there's a problem with Intel C++ and VS2005 SP1 (to be fixed in the next 9.1 update) but Fortran does not seem to be affected.
kstultz
Steve,
FWIW, we've done some testing on this in the last few days and the problem occurs only when we are using a computer with Win64 as the operating system. As long as we stick with computers using Win32 we have no trouble getting C# to call Fortran.
Which operating system were you using?
Thanks, Kenny
I was using 32-bit Windows. My understanding is that you can't mix 32 and 64 bit code and that you need to have a 64-bit DLL for this purpose on Win64. I have not tried this environment, however.
wisperless
That's right. I am using 64 bits machine and I have to recompile everything using 64bit settings in the VC 2005. Otherwise, it won't work
