29376 Discussions
C++ pointer pass to Fortran in Fortran/C++ mixed program
Zhanghong_T_
Dear all,
I have some problems in passing C++ pointer to Fortran when working on Fortran/C++ mixed program.
I use the VS2010 to build C++ DLL and Intel Fortran main program. C++ code:
// cppdll.cpp : Defines the exported functions for the DLL application.
typedef struct outputobj0
int intarraysize;
int doublearraysize;
int *intarray;
double *doublearray;
}outputobj;
extern "C" void C_ASSIGN_ARRAY_TO_FORTRAN(outputobj *obj)
obj->intarraysize=10;
obj->doublearraysize=10;
int *intarray=new int[obj->intarraysize];
double *doublearray=new double [obj->doublearraysize];
for (int i=0;iintarraysize;i++)
intarray=i;
for (int i=0;idoublearraysize;i++)
doublearray=i;
obj->intarray=intarray;
obj->doublearray=doublearray;
Fortran code:
implicit none
type mystruct
integer::intsize
integer::doublesize
integer,pointer::intarray(:)
real*8,pointer::doublearray(:)
end type
type(mystruct)::test
integer::i
call C_ASSIGN_ARRAY_TO_FORTRAN(test)
write(*,*)test%intsize
write(*,*)test%doublesize
do i=1,test%intsize
write(*,*)test%intarray(i)
enddo
do i=1,test%doublesize
write(*,*)test%doublearray(i)
enddo
end
Results show that the C++ pointer hasn't been passed into Fortran. How to modify the code to let the C++ pointer pass to the Fortran correctly?
Zhanghong Tang
PS: the whole project is also attached.
TimP
A Fortran pointer is much more complicated than a C pointer (which is more like a Fortran Cray pointer). You would receive the C pointer as integer(c_ptr) and use c_f_pointer to make a Fortran pointer from it.
Zhanghong_T_
Hi Timp,
Thank you very much for your kindly reply. Could you please help me to modify the code to let the program output the correct result?
I wish the test%intarray and test%doublearray can be used as before.
Zhanghong Tang
Zhanghong_T_
Dear all,
Could anyone tell me how to modify the code to pass the struct to C++ code and let the C++ allocate arrays and then access them by Fortran as usual way (like test%intarray and test%doublearray)?
Zhanghong Tang
IanH
Use C interop from F2003.
[fortran]  USE, INTRINSIC :: ISO_C_BINDING, ONLY: C_INT, C_DOUBLE, C_PTR,  &
      C_F_POINTER
  IMPLICIT NONE
  TYPE, BIND(C) :: MyStruct_C
    INTEGER(C_INT) :: intarraysize
    INTEGER(C_INT) :: doublearraysize
    TYPE(C_PTR) :: intarray
    TYPE(C_PTR) :: doublearray
  END TYPE MyStruct_C
  TYPE :: MyStruct
    INTEGER(C_INT), POINTER :: intarray(:)
    REAL(C_DOUBLE), POINTER :: doublearray(:)
  END TYPE MyStruct
  INTERFACE
    SUBROUTINE C_ASSIGN_ARRAY_TO_FORTRAN(obj)  &
        BIND(C, NAME='C_ASSIGN_ARRAY_TO_FORTRAN')
      IMPORT :: MyStruct_C
      IMPLICIT NONE
      TYPE(MyStruct_C), INTENT(OUT) :: obj
    END SUBROUTINE C_ASSIGN_ARRAY_TO_FORTRAN
  END INTERFACE
  TYPE(MyStruct_C) :: test_c
  TYPE(MyStruct) :: test
  CALL C_ASSIGN_ARRAY_TO_FORTRAN(test_c)
  CALL C_F_POINTER( test_c%intarray, test%intarray,  &
      [test_c%intarraysize] )
  CALL C_F_POINTER( test_c%doublearray, test%doublearray,  &
      [test_c%doublearraysize] )
  WRITE (*, *) SIZE(test%intarray)
  WRITE (*, *) SIZE(test%doublearray)
  WRITE (*, *) test%intarray
  WRITE (*, *) test%doublearray
END
[/fortran]
