29271 Discussions
CAn't change the installation directory from /opt/intel -- The install directory path cannot be changed because at least one software product component was detected as having already been installed on the system
James_Williams
I unisntalled the intel cluster studio from our SUSE cluster because it had been deploy in a path that is not in accordance with our standard.
Now i want to install it back but it is telling me that it cant install it because:
"The install directory path cannot be changed because at least one software product component was detected as having already been installed on the system."
But i cant find any componet of the package installed? how do i fix this?
1. Start installation Now
2. Change install directory [ /opt/intel ]
3. Change components to install [ Custom ]
4. Change advanced options [ Current node ]
5. Show pre-install summary
h. Help
b. Back to the previous menu
q. Quit
Please type a selection or press "Enter" to accept default choice [1]: 2
Finish component selection
2. Intel Cluster Tools 2011 for Linux*
3. Intel MPI Library
4. Intel Trace Analyzer and Collector
5. Intel Math Kernel Library 10.3 for Linux*
(for applications running on IA-32)
6. Intel Math Kernel Library 10.3 for Linux*
(for applications running on Intel 64)
7. Intel MPI Benchmarks
[ ] Intel Cluster Studio Common Files (already installed)
h. Help
q. Quit
TimP
It looks like a related Intel software application has been installed under /opt/intel. You could try
find /opt/intel -name uninstall*
and then run (as root) any uninstall script which is discovered there.
If all the uninstall scripts have been deleted, root could run a command such as
rpm -qa | grep intel
and then run
rpm -e
on any Intel software tool rpms you find which need to be removed so as to permit your installation to proceed.
