CFI_setpointer segmentation fault
faustino_de_sousa__j
Hi all!
I am having a segmentation fault at CFI_setpointer with this code:
#include <stdlib.h>
#include <assert.h>
#include "ISO_Fortran_binding.h"
int main(int argc, char **argv){
  CFI_CDESC_T(0) yp;
  int stat;
  stat = CFI_establish((CFI_cdesc_t*)&yp, NULL, CFI_attribute_pointer, CFI_type_int, sizeof(CFI_type_int), 0, NULL);
  assert(stat== CFI_SUCCESS);
  stat = CFI_setpointer((CFI_cdesc_t*)&yp, NULL, NULL);
  assert(stat==CFI_SUCCESS);
  return EXIT_SUCCESS;
Needs -lifcore to compile.
Is there a way not to get warnings about C standard disconformities in ISO_Fortran_binding.h when compiling with -strict-ansi?
Thank you very much.
José Rui
FortranFan
Please file a support request incident with Intel if you can do so.
FortranFan
MWind2
New Contributor III
I'm not set up for linux with Intel compilers, but when I tried to compile in Windows, I got a complaint about a zero length array for
CFI_CDESC_T(0) yp;
