CLARIFICATION ON FORTRAN DOWNLOADS
desouzasantos
I have downloaded the Intel Visual Fortran for IA-32 and Intel 64 (with Microsoft Visual 2008 Shell and Libraries, English version).
To work with IMSL libraries, should I download and install
IMSL* Library for Intel 64orIMSL* Library for IA-64? Do I need to download the Redistributable Libraries for 64 b as well?
thank you
TimP
The library for Intel64 would match the Intel64 compiler. IA-64 means Itanium, a different 64-bit architecture, incompatible with Intel64.
If you mean the redistributable libraries for ifort, those are used to support dynamic linked applications on a computer without full installation of ifort.
desouzasantos
Thank you. Problem solved.
