CLASS question
OP1
New Contributor III
The code below does not compile with XE 17 (probably justly so). It compiles if U and V are not declared as allocatable arrays.The help for CLASS in the provided documentation does not seem to cover this case, maybe I am missing something here?
PROGRAM P
IMPLICIT NONE
TYPE,ABSTRACT :: T
END TYPE T
TYPE,EXTENDS(T) :: T1
END TYPE T1
TYPE(T1),ALLOCATABLE :: U(:)
CALL S(U)
CONTAINS
SUBROUTINE S(V)
IMPLICIT NONE
CLASS(T),ALLOCATABLE :: V(:)
END SUBROUTINE S
END PROGRAM P
IanH
This isn't permitted.  Inside `S`, you could (re-)allocate the `V` dummy argument to be some other extension of `T`, that was incompatible with the declared type of the actual argument `U`.  To avoid this there is a requirement that the declared type and polymorphic/non-polymorphic nature of the actual and dummy arguments must match if the dummy has the pointer or allocatable attribute (F2008 12.5.2.5p2).
I found a hint of an incomplete mention of this in the ifort documentation for allocatable arrays under "Array arguments", but it applies to scalar dummy arguments and pointer dummy arguments too.
OP1
New Contributor III
Ah, I understand now. Thanks for the clear explanation!
