COM dll can not be registered (errorcode 0x80040201)
Matthias
I work on a project, where I use Fortran Code inside a COM server to call it from Matlab. I have set it up in WindowsXP (32bit), where everything worked fine. Now, I migrated the project to Windows7 (64bit) and I have trouble to register the server. The 32bit version does not work, as matlab is installed as 64bit and this version requires a 64bit COM server to work with.
The project was set up using Visual Studio 2003 and the Fortran Composer in XP. On the windows7 machine (VS2010 pro and Visual Fortran Composer XE 2011) I use a exact copy of the project, I have simply added the x64 configuration in the configuration manager, selected it and rebuild the complete project. Compiling and building the project worked fine. When I try to register the server using:
regsvr32 PROJECTPATH\x64\Release\PROJECTNAME.dll
I get an error message with code 0x80040201. I have run it under adminitrator-mode and I can register the 32bit version successfully using the same call with out the "\x64". Does anyone have an idea, what could be wrong?
Thank you,
Matthias
SergeyKostrov
Valued Contributor II
>>...I use Fortran Code inside a COM server to call it from Matlab. I have set it up in WindowsXP (32bit), where everything >>worked fine. Now, I migrated the project to Windows7 (64bit) and I have trouble to register the server. The 32bit version >>does not work, as matlab is installed as 64bit and this version requires a 64bit COM server to work with... Try to use MS Depends or Editbin utilities to verify all dependencies for the 32-bit DLL. Also, I found two references for the error 0x80040201 in Windows header files: ... // // MessageId: EVENT_E_ALL_SUBSCRIBERS_FAILED // // MessageText: // // An event was unable to invoke any of the subscribers // #define EVENT_E_ALL_SUBSCRIBERS_FAILED _HRESULT_TYPEDEF_(0x80040201L) ... and ... CDO_E_UNCAUGHT_EXCEPTION = 0x80040201L; ... and they do not explain an exact reason of your problems.
Bernard
IIRC 32-bit app when executed on 64-bit Windows are subjected to hooking and redirection of their calls by WOW layer.There is also different view of registry for 32-bit app.Maybe this could be a reason of your registration problem
SergeyKostrov
>>...I use a exact copy of the project, I have simply added the x64 configuration in the configuration manager, selected it and rebuild the complete project... Could you upload the VS project ( sln and proj files ) for review? Note: you don't need to upload any source files and it is needed to review all project settings.
Matthias
Thank you for your fast responses. I am back in the office today and now I can work on this project again.
The solution file is:
Microsoft Visual Studio Solution File, Format Version 11.00
# Visual Studio 2010
Project("{6989167D-11E4-40FE-8C1A-2192A86A7E90}") = "Server4", "Server4\Server4.vfproj", "{36ACC53A-F0F2-4577-A9EE-98EC308953E4}"
EndProject
Project("{6989167D-11E4-40FE-8C1A-2192A86A7E90}") = "Console1", "Console1\Console1.vfproj", "{492CE5A3-4336-4969-9893-2C4D0B4ADBEF}"
EndProject
Global
    GlobalSection(SolutionConfigurationPlatforms) = preSolution
        Debug|Win32 = Debug|Win32
        Debug|x64 = Debug|x64
        Release|Win32 = Release|Win32
        Release|x64 = Release|x64
    EndGlobalSection
    GlobalSection(ProjectConfigurationPlatforms) = postSolution
        {36ACC53A-F0F2-4577-A9EE-98EC308953E4}.Debug|Win32.ActiveCfg = Debug|Win32
        {36ACC53A-F0F2-4577-A9EE-98EC308953E4}.Debug|Win32.Build.0 = Debug|Win32
        {36ACC53A-F0F2-4577-A9EE-98EC308953E4}.Debug|x64.ActiveCfg = Debug|x64
        {36ACC53A-F0F2-4577-A9EE-98EC308953E4}.Debug|x64.Build.0 = Debug|x64
        {36ACC53A-F0F2-4577-A9EE-98EC308953E4}.Release|Win32.ActiveCfg = Release|Win32
        {36ACC53A-F0F2-4577-A9EE-98EC308953E4}.Release|Win32.Build.0 = Release|Win32
        {36ACC53A-F0F2-4577-A9EE-98EC308953E4}.Release|x64.ActiveCfg = Release|x64
        {36ACC53A-F0F2-4577-A9EE-98EC308953E4}.Release|x64.Build.0 = Release|x64
        {492CE5A3-4336-4969-9893-2C4D0B4ADBEF}.Debug|Win32.ActiveCfg = Debug|Win32
        {492CE5A3-4336-4969-9893-2C4D0B4ADBEF}.Debug|Win32.Build.0 = Debug|Win32
        {492CE5A3-4336-4969-9893-2C4D0B4ADBEF}.Debug|x64.ActiveCfg = Debug|x64
        {492CE5A3-4336-4969-9893-2C4D0B4ADBEF}.Debug|x64.Build.0 = Debug|x64
        {492CE5A3-4336-4969-9893-2C4D0B4ADBEF}.Release|Win32.ActiveCfg = Release|Win32
        {492CE5A3-4336-4969-9893-2C4D0B4ADBEF}.Release|Win32.Build.0 = Release|Win32
        {492CE5A3-4336-4969-9893-2C4D0B4ADBEF}.Release|x64.ActiveCfg = Release|x64
        {492CE5A3-4336-4969-9893-2C4D0B4ADBEF}.Release|x64.Build.0 = Release|x64
    EndGlobalSection
    GlobalSection(SolutionProperties) = preSolution
        HideSolutionNode = FALSE
    EndGlobalSection
EndGlobal
and the project file (server4.vfproj) is:
[<?xml version="1.0" encoding="UTF-8"?>
<VisualStudioProject ProjectType="typeDynamicLibrary" ProjectCreator="Intel Fortran" Keyword="COM Server" Version="11.0" ProjectIdGuid="{36ACC53A-F0F2-4577-A9EE-98EC308953E4}">
    <Platforms>
        <Platform Name="Win32"/>
        <Platform Name="x64"/></Platforms>
    <Configurations>
        <Configuration Name="Debug|Win32" ConfigurationType="typeDynamicLibrary">
                <Tool Name="VFFortranCompilerTool" SuppressStartupBanner="true" DebugInformationFormat="debugEnabled" ParallelizerDiagLevel="parallelizerDiagLevel1" DebugParameter="debugParameterAll" WarnInterfaces="true" Interfaces="true"/>
                <Tool Name="VFLinkerTool" SuppressStartupBanner="true" ModuleDefinitionFile="Server4.def" GenerateDebugInformation="true" LinkDLL="true"/>
                <Tool Name="VFResourceCompilerTool" AdditionalIncludeDirectories="$(IntDir)\"/>
                <Tool Name="VFMidlTool" AdditionalOptions="/cpp_cmdifort /cpp_opt&quot;/nologo /fpp /P /E /Qoption,fpp,/no-fort-cont&quot;" SuppressStartupBanner="true"/>
                <Tool Name="VFCustomBuildTool"/>
                <Tool Name="VFPreLinkEventTool"/>
                <Tool Name="VFPreBuildEventTool"/>
                <Tool Name="VFPostBuildEventTool"/>
                <Tool Name="VFManifestTool" SuppressStartupBanner="true"/></Configuration>
        <Configuration Name="Release|Win32" ConfigurationType="typeDynamicLibrary">
                <Tool Name="VFFortranCompilerTool" SuppressStartupBanner="true" RuntimeLibrary="rtMultiThreadedDLL"/>
                <Tool Name="VFLinkerTool" SuppressStartupBanner="true" ModuleDefinitionFile="Server4.def" SubSystem="subSystemWindows" LinkDLL="true"/>
        <Configuration Name="Debug|x64" ConfigurationType="typeDynamicLibrary">
                <Tool Name="VFFortranCompilerTool" DebugInformationFormat="debugEnabled" ParallelizerDiagLevel="parallelizerDiagLevel1" DebugParameter="debugParameterAll" WarnInterfaces="true" Interfaces="true"/>
                <Tool Name="VFLinkerTool" ModuleDefinitionFile="Server4.def" GenerateDebugInformation="true" LinkDLL="true"/>
                <Tool Name="VFMidlTool" AdditionalOptions="/cpp_cmdifort /cpp_opt&quot;/nologo /fpp /P /E /Qoption,fpp,/no-fort-cont&quot;" SuppressStartupBanner="true" TargetEnvironment="midlTargetAMD64"/>
        <Configuration Name="Release|x64" ConfigurationType="typeDynamicLibrary">
                <Tool Name="VFManifestTool" SuppressStartupBanner="true"/></Configuration></Configurations>
    <Files>
        <Filter Name="Do Not Edit">
        <File RelativePath=".\Generated\clsfact.f90"/>
        <File RelativePath=".\Generated\clsfactty.f90"/>
        <File RelativePath=".\Generated\dllmain.f90"/>
        <File RelativePath=".\Generated\IServer4.f90"/>
        <File RelativePath=".\Generated\server.idl"/>
        <File RelativePath=".\Generated\Server4Global.f90"/>
        <File RelativePath=".\Generated\Server4TY.f90"/>
        <File RelativePath=".\Generated\serverhelper.f90"/></Filter>
        <Filter Name="Header Files" Filter="fi;fd"/>
        <Filter Name="Resource Files" Filter="rc;ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe">
        <File RelativePath=".\Server4.rc"/></Filter>
        <Filter Name="Source Files" Filter="f90;for;f;fpp;ftn;def;odl;idl">
        <File RelativePath="..\..\code\eos.f"/>
        <File RelativePath="..\..\code\eos_const.f"/>
        <File RelativePath="..\..\code\eos_enthalpy.f"/>
        <File RelativePath="..\..\code\hybrd.f"/>
        <File RelativePath="..\..\code\kub_eos.f"/>
        <File RelativePath="..\..\code\main_prog_2.f"/>
        <File RelativePath="..\..\code\mm.f"/>
        <File RelativePath="..\..\code\para.f"/>
        <File RelativePath="..\..\code\phase.f"/>
        <File RelativePath="..\..\code\param_db.f"/>
        <File RelativePath=".\Server4.def"/>
        <File RelativePath=".\Generated\UIServer4.f90"/>
        <File RelativePath=".\Generated\UServer4TY.f90"/>
        <File RelativePath="..\..\code\utilities.f"/></Filter>
        <File RelativePath=".\ReadMe.txt"/>
        <File RelativePath=".\Server4.hie"/></Files>
    <Globals/></VisualStudioProject>
The second project in the solution (console1) is the same code, but for use in the console. This project works fine in 64 and 32 bit.
Also I have verified the dependencies of the 64bit and the 32bit dlls using dependency walker. For the 64bit all dependencies are 64bit. The 32bit dll pointed exclusively to 64bit system dll's. Would the full output be helpful?
Thank you for you help!
Matthias
SergeyKostrov
Could you upload Microsoft Visual Studio Solution File, Server4.vfproj and Console1.vfproj files?
Matthias
I am sorry, here they are: (I have renamed the .vfproj to .vfproj.txt, as the upload is not allowed.)
SergeyKostrov
Thanks and I'll take a look. Note: My primary concern is if a Target Machine is properly set in Advanced Linker settings.
SergeyKostrov
>>...The 32bit version does not work... Target Machine for 32-bit platforms and configurations ( Debug and Release ) is not set ( current value is 'Not Set' ).
Matthias
Thank you for the comment and for checking these things. The 32bit version does not work for me, as I use 64bit matlab. The 64bit matlab does not support calling a 32bit COM-dll.
But your advise is correct! If I change the Target Machine setting to 32-bit and check the dll dependencies again, the 32-bit system dll's are correctly called. I cannot see a corresponding option for the 64-bit version. Is this ok, or am I doing something wrong?
PS: I really appreceate your help a lot. The long response time is due to other projects, that have stricter deadlines. It does not mean, that I don't care about your answers.
SergeyKostrov
>>...I cannot see a corresponding option for the 64-bit version. Is this ok, or am I doing something wrong? Consider it as a feature at the moment and this is how it works: 32-bit Configurations: Target Machine needs to be set to MachineX86 64-bit Configurations: Target Machine needs to be set to Not Set A message to Steve: I wonder if it could be changed to: 32-bit Configurations: Target Machine needs to be set to MachineX86 64-bit Configurations: Target Machine needs to be set to MachineX64 Thanks.
Steven_L_Intel1
No - that setting really isn't used anymore. Leave it "not set". The problem generally occurs when you migrate an old CVF project that explicitly had X86 set there.
