29386 Discussions
COMPOSER XE 2011 in Visual Studio 2010
Thomas_L_3
I have installed COMPOSER XE 2011 on a Windows 2008 R2 server with Visual Studio 2010.   The install was done in 2012 and has been running well until today.   With no known changes to FORTRAN or VS, I can no longer compile.   Any routine that attempts a FORTRAN compile causes a problem with routine fcA40B_tmp.exe.    We can still compile C++ routines so the problem is only related to FORTRAN.
I have also tried to re-install/repair and get an error trying to read existing licenses in chklic.exe.   I did not think Intel licenses had an expiration date but the problems appear to be license related.
Any thoughts/experience with these sorts of problems with COMPOSER after about 3-1/2 years?
mecej4
I think that more specific details about how you attempt to compile, the location (directory) where you do so, the error messages that you see, etc., are needed. If you do the build within Visual Studio, capture and post the build log (buildlog.htm) in your reply. If you use the command line, copy/paste the text from the command window.
