COPILOT
JohnNichols
Valued Contributor III
Copilot is a new addition to Windows 11, it is like ChatGPT, I just asked for a solution in Fortran to the Euler problem and got
program euler
  implicit none
  integer :: n, m, i, j, k, start, current, next
  integer, dimension (:,:), allocatable :: adj
  logical, dimension (:,:), allocatable :: visited
  integer, dimension (:), allocatable :: path, degree
  logical :: is_eulerian, is_semi_eulerian
  ! Read the number of vertices and edges
  print *, 'Enter the number of vertices and edges:'
  read *, n, m
  ! Allocate the arrays
  allocate (adj(n,n), visited(n,n), path(m+1), degree(n))
  ! Read the adjacency matrix
  print *, 'Enter the adjacency matrix:'
  do i = 1, n
    read *, (adj(i,j), j = 1, n)
  end do
  ! Initialize the visited matrix and the degree array
  visited = .false.
  degree = 0
  ! Count the degrees of each vertex
  do i = 1, n
    do j = 1, n
      degree(i) = degree(i) + adj(i,j)
    end do
  end do
  ! Check if the graph is Eulerian or semi-Eulerian
  is_eulerian = .true.
  is_semi_eulerian = .false.
  k = 0
  do i = 1, n
    if (mod(degree(i), 2) /= 0) then
      is_eulerian = .false.
      k = k + 1
      if (k == 1) then
        start = i ! Save the first odd degree vertex as the start point
      end if
    end if
  end do
  if (k == 2) then
    is_semi_eulerian = .true.
  end if
  ! Print the result
  if (is_eulerian) then
    print *, 'The graph is Eulerian and has an Euler circuit.'
    start = 1 ! Choose any vertex as the start point
  else if (is_semi_eulerian) then
    print *, 'The graph is semi-Eulerian and has an Euler path.'
  else
    print *, 'The graph is neither Eulerian nor semi-Eulerian and has no Euler path or circuit.'
    stop
  end if
  ! Find the Euler path or circuit
  current = start
  k = 1
  path(k) = current
  do while (k < m + 1)
    do j = 1, n
      if (adj(current,j) > 0 .and. .not. visited(current,j)) then
        next = j ! Choose the next vertex
        exit
      end if
    end do
    visited(current,next) = .true. ! Mark the edge as visited
    visited(next,current) = .true.
    current = next ! Move to the next vertex
    k = k + 1
    path(k) = current ! Add the vertex to the path or circuit
  end do
  ! Print the path or circuit
    print *, 'The Euler circuit is:'
  else
    print *, 'The Euler path is:'
  end if
  print *, (path(i), i = 1, m + 1)
  ! Deallocate the arrays
  deallocate (adj, visited, path, degree)
end program euler
Soon humans will not write code?
JohnNichols
solve 2nd order DE
program harmonic
  implicit none
  integer :: n, i
  real :: h, x, y, z
  real, dimension (:), allocatable :: xarr, yarr, zarr
  ! Read the number of steps and the step size
  print *, 'Enter the number of steps and the step size:'
  read *, n, h
  allocate (xarr(n+1), yarr(n+1), zarr(n+1))
  ! Set the initial conditions
  x = 0.0
  y = 1.0
  z = 0.0
  ! Store the initial values in the arrays
  xarr(1) = x
  yarr(1) = y
  zarr(1) = z
  ! Loop over the steps
  do i = 1, n
    ! Call the Runge-Kutta subroutine to update x, y, and z
    call rk4sys(h, x, y, z)
    ! Store the updated values in the arrays
    xarr(i+1) = x
    yarr(i+1) = y
    zarr(i+1) = z
  end do
  ! Print the results
  print *, 'The results are:'
  do i = 1, n+1
    print *, xarr(i), yarr(i), zarr(i)
  end do
  deallocate (xarr, yarr, zarr)
contains
  ! Subroutine to implement the Runge-Kutta method (order 4) for systems of ODEs
  subroutine rk4sys(h, x, y, z)
    implicit none
    real, intent (in) :: h
    real, intent (inout) :: x, y, z
    real :: k1, k2, k3, k4, l1, l2, l3, l4
    ! Calculate the coefficients
    k1 = h * z
    l1 = h * f(x, y, z)
    k2 = h * (z + 0.5 * l1)
    l2 = h * f(x + 0.5 * h, y + 0.5 * k1, z + 0.5 * l1)
    k3 = h * (z + 0.5 * l2)
    l3 = h * f(x + 0.5 * h, y + 0.5 * k2, z + 0.5 * l2)
    k4 = h * (z + l3)
    l4 = h * f(x + h, y + k3, z + l3)
    ! Update the values of x, y, and z
    x = x + h
    y = y + (k1 + 2.0 * k2 + 2.0 * k3 + k4) / 6.0
    z = z + (l1 + 2.0 * l2 + 2.0 * l3 + l4) / 6.0
  end subroutine rk4sys
  ! Function to define the right hand side of the system of equations
  function f(x, y, z)
    implicit none
    real, intent (in) :: x, y, z
    real :: f
    f = -y
  end function f
end program harmonic
JohnNichols
