CSHIFT problem in sub-arrays
electricb
Hello, I am having trouble using CSHIFT with a sub-array. Maybe an example would explain this better:
*** START PROGRAM ****
INTEGER,ALLOCATABLE,DIMENSION(:)::indice
INTEGER::i
ALLOCATE(indice(0:10))
DO i=0,10
indice(i) = i
END DO
WRITE(*,*) indice
indice(3:10) = CSHIFT(indice(3:10), 1)
WRITE(*,*) indice
DEALLOCATE(indice)
**** END PROGRAM ****
I want to cshift the end of the vector so that 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 becames 0, 1, 2, 4, 5, 6, 7, 8, 9, 10, 3. But I am getting the following output:
**** BEGIN OUTPUT ****
0 1 2 3 4 5 6 7 8 9 10
0 1 2 9 9 9 9 9 9 9 9
*** END OUTPUT ***
I am using Intel Fortran Compiler for Linux (i32) 9.0
Micah_Elliott
Looks like a bug in early 9.0 compilers. I can see that it works properly on ifort-9.0.024 and newer compilers, including any 9.1.
electricb
madmdelliot, thanks for the tip. I updated to the latest 9.1 compiler and the problem is gone. Now that was a strange one.
