CVF library and IVF9.1
saudreau
Hello all,
I'm new to this forum and have just installed the trial-version of Intel's Visual Fortran Compiler for Windows.
When i am trying to compile my code (command line), I have got the following error message:
Fatal error cannot open "dfor.lib"
ifort: error: problem during multi-file optimization compilation (code 1)
NMAKE : fatal error U1077: '"C:Program FilesIntelCompilerFortran9.1Ia32Binifort.EXE"': code retour '0x1'
I have a look at the forum and it seems to me that the problem comes from a library file created with CVF. How can I do to use a library coming from CVF with IVF ? (If I'm right !!)
Thank you for your help !!
Marc
You're right that this is the problem. You cannot use the CVF-built library with Intel Fortran - you must get a library that was built with Intel Visual Fortran.
saudreau
Ok ... I will work a little bit more !!!
Thank you for your quick reply.
Marc Saudreau
xwangok
I am migrating from CVF to IVF. I know I can't use CFV library.
Can I use library compiled by intel Fortram compiler 9.0?
Yes - anything compiled by Intel Fortran 8.0 or later is fine.
xwangok
Thanks a lot.
