29277 Discussions
CVF 6.6B Run Time Libraries and Compiles
Intel_C_Intel
I recently updated one machine I have to CVF 6.6B Pro. Wow! The compile times of my big project went from an hour (using 6.1.?) to 15 minutes or so with 6.6B. I keep looking for compiler switches that could have been changed unintentionally, but haven't found any. Anybody else have this experience? The projects have a few dozen console executables that do many system calls and the executables are left in debug mode.
Also, has anyone tried running the CVF 6.1 compiler/development studio on a machine that has had the 6.6 distributable run time installed? I will likely run into that prospect in the near future. Any reason to thing this will not work? Thanks.
If your program uses DFWIN or other large modules, you would have definitely seen a compile time improvement as of 6.5. We also made improvements throughout the compiler over the past three years (6.1 is from 1999.) A good reason to keep up to date!
I know of no reason the combination of 6.1 compiler and 6.6B runtime shouldn't work.
Steve
Intel_C_Intel
Thanks for the expedient reply, Steve. I am pushing to get all our copies of CVF updated, but I will have to deploy some programs written with 6.6B that will likely end up on machines with previous versions of the CVF. If I do run into unexpected problems, I'll let you know.
