29285 Discussions
CVF bindings for LIBIFPORT.LIB functions
michael_nielson
The portability functions found in LIBIFPORT.LIB library don't seem to have entry points with CVF bindings. For example FSEEK exists, but FSEEK@... does not. Are CVF bindings supported?
No. As with CVF, only default interfaces are supported.
You should be able to use module IFPORT to define the interfaces, but there's a bug in that the DEFAULT attribute doesn't work if /iface:cvf is specified. That should be fixed in an upcoming update.
