29286 Discussions
CVF dll Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Nick2
One of my latest builds with CVF 6.6 has a strange problem when I compile it as a DLL (versus stand-alone executable). Namely, when I try to call the DLL from my managed code, I get this:
To make this more fun, here's what I tried...I tried running the manged front end with a different DLL, and it works fine. I tried to compile my Fortran with IVF instead of CVF, and then it works fine too.
Any ideas why or how to troubleshoot this?
Nick
Nick2
Apparently my project settings were messed up...
Good flags:
# ADD F90 /automatic /browser /check:bounds /check:overflow /compile_only /fpe:0 /include:"Release/" /dll /libs:static /nologo /recursive /reentrancy:none /traceback /warn:argument_checking /warn:nofileopt
# SUBTRACT F90 /threads /winapp /fast
Bad flags:
# ADD F90 /automatic /browser /check:bounds /check:overflow /compile_only /fpe:0 /include:"Release/" /dll /libs:static /nologo /recursive /reentrancy:threaded /threads /traceback /warn:argument_checking /winapp
# SUBTRACT F90 /warn:nofileopt /fast
