I am on Windows Server 2003, Standard Edition/S.P. 1. Not Win95.
The Fortran Prog I inherited and it had been created/debugged, etc.; i.e., itshould work. But I had to get it to compile/link in CVF on my machine. I only changed 1 thing in the code-did not redimen any arrays. It does call a lot of third-party libs, etc. The agony was getting all these files together and configuring them properly in the IDE and in proper folders.
The exec image generatedis only 268K--is that correct or does the warning suggest otherwise? This is confusing since I get unexpected, incorrect results so I do not know if the image should be ~350M and, if system could accomodate it, would yield correct results. But it does run w/o err.
What happens when your compiler options are set for minimum size? (and favor size over speed and no loop unrolling, etc...)
Jim Dempsey
The size of the .EXE file does not tell you how much static code and data is in the application.
