29413 Discussions
CVF6.6B - !DEC$IF parsing - Is it as it should be?
Jugoslav_Dujic
Valued Contributor II
I upgraded to 6.6B and I was pleasantly surprised how it caught few errors that were left unnoticed in 6.6A (misordered names in USE,ONLY lists and a few assumed-shape/assumed-array/scalar argument mismatches). However, apparently parsing of !DEC$IF parsing was changed as well. The following program:
!DEC$DEFINE _ENGLISH
PROGRAM Test
!DEC$IF DEFINED (_ENGLISH)
      WRITE(*,*)
!DEC$ELSE
      CALL ErrHandler('a' // &
            STRING(isiftse(i),9)'b'
            STRING(isifrasab,9),2)
!DEC$ENDIF
END PROGRAM Test
Produces
D:UsersDujaCodeTestTest.f90(9) : Error: Unbalanced parentheses
Not all syntax errors in a code that is supposedly not compiled will trigger such errors -- mostly, it is sensitive to some combinations with line continuations. Now, I recall Steve said once that !DEC$IF is not semantically identical to #ifdef...#endif. Should I file a bug report or is this as it should be? (But if it is, I can't figure out the rules?).
Jugoslav
What do you think this should have done? The code in the ELSE clause looks very strange to me - definitely incorrect. I'm not sure what your complaint is.
!DEC$ IF is not like #ifdef in that !DEC$ IF operates on entire statements, not source lines.
Steve
Jugoslav_Dujic
I see now. Forget it -- just a minor inconvenience. The actual code between ELSE...ENDIF where it popped out was never meant to be compiled at all (long story). My point was -- why should compiler even care about the contents of "commented" code. 6.6A acted as if !DEC$IF was line-based, not statement-based.
Jugoslav
6.6A was still statement-based but text that would not be compiled was still run through syntax analysis. I think we have it in 6.6B that it won't complain about code it won't compile.
Steve
james1
It appears to be complaining in this case. Seems to only care if there are too many ")". One would expect this code to be ignored.
James
Oh, I get it now... Sometimes I'm a bit slow to catch on...
Steve
Jugoslav_Dujic
Should I file a bug report or I may consider it already done?
Jugoslav
I'll take care of it - thanks.
Steve
