I have a CFD code that does a lot of element-wise (A(i,j)+B(i,j)) math with large arrays. roughly 500x500 R*8s, with most sections of the code using a half dozen of these (1.5MB) arrays at a time.
To clean up the code, and in a naive hope that IFC would figure out the best way to manage the work, we vectorized most of the code.
VTune shows a lot of time wasted with various stores.
Is there a simple technique or a library that can block these operations to be efficient on a Xeon? Hopefully without rewriting all the code!
You may want to ask this in the Integrated Performance Primitives and Math Kernel Library boards. Have you tried compiling with /opt:3?
