Call Error
JohnNichols
Honored Contributor I
Steve:
I fixed the WULF program for the stack error. Thanks for the help.
​I tried to put a note of thanks and a picture on this forum but it got lost again.
​First call to PXFCDDIR fails. IFPOSIX - as use statement does not work either.
John
      subroutine chdirA(i)
      use IFPORT
      implicit none
      CHARACTER(len=255) :: path
      integer i,ilen, ierror
      CALL PXFGETCWD (path,ilen,ierror)
      WRITE(*,*) TRIM(path)
      call PXFCHDIR("C:\",3,i)
      call PXFCHDIR("users\macne\documents\Visual Studio 2013\Projects\Program070 - Beams\Lothurr",76,i)
       write(*,*)i
       return
       end subroutine
JohnNichols
Picture of error
Steve: The other picture is the result from the FFT analysis. This is based on Kappler's 1931 research in Germany on vibration due a differential number of atoms hitting the surface causing vibration.  The movement is 10 billionth of a meter.  Picture is acceleration
Thanks for the help
John
JohnNichols
I also worked out the incorrect posts occur when I upload a picture in a post that creates a new topic.
Ying from the MKL pointed out the error - this code came in part from the MKL examples, perhaps these could be adjusted.
John
JohnNichols
This is where I got the code from
mecej4
The second argument to PFXCHDIR is the length of the input string, which is the first argument, as you can see from the documentation at https://software.intel.com/en-us/node/580986.
In your code of #1, before line-21 insert "      ilen=255".
jimdempseyatthecove
Although the documentation does not state this, try concatenating a null character to your directory string (do not count it).
call PXFCHDIR("users\macne\documents\Visual Studio 2013\Projects\Program070 - Beams\Lothurr"//char(0),76,i)
(and elsewhere on calls)
Jim Dempsey
JohnNichols
Thanks you for the comments - the interesting issue is the code works perfectly in a program by itself, it just stops working when I turn the program into a subroutine and call it.
JohnNichols
Guys:
The following code works perfectly - just not as subroutine - WULF was not fixed with the suggested changes
 !  ChDir - Entry point of console application.
    !  PROGRAM: ChDir
    !  PURPOSE:  Entry point for the console application.
    program ChDir
    use IFPORT
    implicit none
    ilen = 255
    write(*,*)i
    end program ChDir
