Gives warning while compilation
shalabh_a_
ifort: warning #10362: Environment configuration problem encountered.  Please check for proper MPSS installation and environment setup.
Please show the compile command you are using. Are you trying to compile a program that offloads work to an Intel Xeon Phi coprocessor?
shalabh_a_
I am giving the command as ifort code_name.f90. Initially it was working, but from last week it gives the warning
Please attach the source file you are trying to compile.
Kevin_D_Intel
That warning can occur when you have language extensions for offload present in the source file, which triggers the target compilation, but where MPSS is not installed. Seeing your source file will help.
You should also verify that MPSS is installed on the system.
