Call Fortran dll in C# Winform
jhlee0301
Hello guys.
I am trying to call Fortran dll from C# Winform.
This is very popular example which we can find in google.
https://stackoverflow.com/questions/10317691/making-fortran-dll-and-calling-it-from-c-sharp
I could success in C# console project but failed in C# Winform.
--- Fortran code ----------
FUNCTION TSAT11(P)
!DEC$ ATTRIBUTES ALIAS:'TSAT11' :: TSAT11
!DEC$ ATTRIBUTES DLLEXPORT :: TSAT11
!DEC$ ATTRIBUTES STDCALL :: TSAT11
!DEC$ ATTRIBUTES VALUE :: P
REAL, INTENT(IN) :: P
REAL :: TSAT11
! Examle calculation
TSAT11 = P - 273.15
RETURN
END FUNCTION
--- C# Console project (This is success) -----------
using System;
using System.Runtime.InteropServices;
namespace ConsoleApp1
class Program
[DllImport(@"D:\Temp\Dll_test1.dll")]
static extern float TSAT11(float P);
static void Main(string[] args)
Console.WriteLine("Hello World!");
float p = 300f;
float t = TSAT11(p);
// returns 26.8500061
Console.WriteLine(t.ToString());
--- C# Winform project -------------
using System;
using System.Windows.Forms;
namespace WindowsFormsApp1
public partial class Form1 : Form
public Form1()
InitializeComponent();
 //[DllImport(@"D:\Temp\Dll_test1.dll", CallingConvention = CallingConvention.StdCall)]
private void btnDoIt_Click(object sender, EventArgs e)
float p = 300f;
float t = TSAT11(p);         //Error still occurs here
MessageBox.Show(t.ToString());
Still I cannot find difference between console project and WinForm project...
Steve_Lionel
You will need to tell us what exactly goes wrong. Screenshots of error messages, etc. It would also be better if you attached a ZIP file of a VS solution with the two projects. I suspect there is not a lot of C# expertise in this forum.
Steve_Lionel
jhlee0301
I found solution.
As you said there is one more thing in VS project file.
In build tab there is "prefer 32 bit" checked box and I unchecked it.
Now it works. Thank you.
