Hi everyboy,
somebody gave me following source.
program main
implicit none
real(8)
x, y, zx = 1.5d0
y = 1.2d0
call
fkt(x,y)end
program mainfunction
fkt(a1, a2)implicit none
real(8)
fkt, a1, a2fkt = a1 * a2
end function
fktI was very surprised when I saw
- that the code was compiled without errors,
- that there were no linker errors,
- that the resulting exe worked without crashes, errors or something similar.
There is a function fkt which is treated as a subroutine (via call ...) by the main program. Is this allowed in standard fortran or is it just a bug? I use Visual Studio 2003 and IVF 9.0.
Thank you in advance
muppets
This is not legal Fortran, but the compiler can't tell because in the main program, there's nothing to indicate that fkt is a function. If you had called fkt in a loop, the program would have died after 8 or so iterations because this mismatch corrupts the floating point stack.
In the version of the compiler you have, it does allow, in some limited circumstances, calling a name known as a function. That has been tightened in version 9.1 so if the compiler knows it's a function, it must be referenced as a function.
