29649 Discussions
Call subroutine defined inside interface block
haitao
The following code is from 'DF98SAMPLESMIXLANGVBCALLBACK' of CVF.
subroutine dll_rout(int_arg,str_in,cbproc1,cbproc2,cbproc3)
!dec$ attributes dllexport ::dll_rout
!dec$ attributes alias :'dll_rout'::dll_rout
use dfcom
! Define interface blocks for each of the callback routines
interface
subroutine cbproc1(c1, i1)
pointer (c1, foo1)
character *(200) foo1
integer*4 i1
end
subroutine cbproc2(c1)
pointer (c1, foo1)
character *(20) foo1
end
subroutine cbproc3(i1)
integer*4 i1
end
end interface
! Define the parameters passed to this routine
integer int_arg
character *(*) str_in
character *25 str_out
integer temp
character *5 int_str
! The following paradigm is used for interfacing to the ConvertStringToBSTR
! routine. The string created is Unicode, which is 16 bit. CHARACTER is
! 8 bit, and so an array of INTEGER*2 are used instead of an array of
! CHARACTERs.
pointer (p1, my_str_in)
pointer (p2, my_str_out)
integer*2 my_str_in(25)
integer*2 my_str_out(25)
integer i
! Multiply the value passed by 10, and give it to cbproc3
temp = int_arg * 10
call cbproc3(temp)
! Convert the integer to string, and append it to the string passed,
! and then give it back to cbproc2 as a BSTR
write(int_str,'(i5.5)')int_arg
str_out = str_in // int_str
p2 = ConvertStringToBSTR(str_out)
call cbproc2(p2)
! Create our message, and pass both it and the original integer to cbproc1
p1 = ConvertStringToBSTR("Fortran says Hello!")
call cbproc1 (p1, int_arg)
! Clean up after ourselves
call SysFreeString(p1)
call SysFreeString(p2)
return
end
The code works fine when called from vb.
My question is how to call the procedure cbproc1 from outside the subroutine dll_rout in fortran. For example, I add a line Call SubTest in dll_rout,
Call SubTest
return
end
subroutine SubTest()
Call cbproc1(1, 2)
return
end
and needto call cbproc1 in SubTest.
The compiler gave me the error message:
callback.obj : error LNK2001: unresolved external symbol _CBPROC1@8
Debug/callback.dll : fatal error LNK1120: 1 unresolved externals
What I want to do is send back the fortran calculated results from a lot of subs called by the main sub.
Thanks in advance for any help,
hhtlib
Jugoslav_Dujic
Valued Contributor II
As with any dummy argument, once you pass it as an argument, symbol cbproc1 is just a synonym/alias/placeholder for a routine defined elsewhere, and which is an actual argument to dll_rout. That means you have to define it to be an dummy argument of any routine that may call it (i.e. SubTest):
call SubTest(cbproc1)
subroutine SubTest(cbproc1)
interface
subroutine cbproc1(...)
end subroutine
end interface
call cbproc1(...)
end subroutine
If you need it in many places, there's another non-standard mechanism (Cray pointers to procedures) supported only by CVF/IVF, which enables such routines tobecome "global":
module imports
interface
end subroutine
end interface
pointer(p_cbproc1, cbproc1)
end module imports
subroutine dll_rout(acbproc1...)
use imports
external acbproc1
p_cbproc1 = loc(acbproc1)
call SubTest
subroutine SubTest
use imports
call cbproc1(...)
end subroutine
I'd really recommend standard method 1) unless the passing dummy arguments around become really awkward.
Jugoslav
haitao
Got it.
Thanks so much.
hhtlib
