Call to C_F_Pointer/ISO_C_BINDING
victor_pp
I am trying to compile the sample code illustrating how to pass correctly derived types from Fortran to C.
Intel Fortran compiler gives the following error message:
fmain.f90(44): error #6285: There is no matching specific subroutine for this generic subroutine call. [C_F_POINTER]
call c_f_pointer(A%status,status,N)
compilation aborted for fmain.f90 (code 1)
It compileswithout problemswith Portland compiler.
What is wrong with this sample?
Victor.
TimP
According to MR&C, if the third argument to c_f_pointer is present, it must be a rank 1 array, where you gave it a scalar. So the compiler treats your c_f_pointer as a generic, not matching the specific version defined in the standard.
If I change that, it runs through the first iteration of your final loop before crashing (apparently due to the discrepancies in your declaration of status).
Arjen_Markus
My guess is that N in the call to c_f_pointer ought to be an array,
in this case an array of one long.
Arjen
TimP
victor_pp
Thank you Arjen and Tim! This did the trick.
The output is now the same asproduced withPortland compiler :
C:\Download\FortranStuff\ISO_C_BINDING>fmain
1 10 100
1 1 10
2 2 9
3 3 8
4 4 7
5 5 6
6 6 5
7 7 4
8 8 3
9 9 2
10 10 1
Victor.
[bash]module type_mod
  use, intrinsic::iso_c_binding
  type, bind(c) :: type2_t
     integer(c_int) :: idx, size
  end type type2_t
  type, bind(c) :: type3_t
  end type type3_t
  type, bind(c) :: type1_t
     type(type2_t) :: params
     type(c_ptr) :: status
  end type type1_t
end module type_mod
program test_f_to_c
  use, intrinsic ::iso_c_binding
  use type_mod
  interface
     subroutine init_data(A,N) bind(c)
       use, intrinsic:: iso_c_binding
       use type_mod
       type(type1_t) :: A
       integer(c_int), value :: N
     end subroutine init_data
  end interface
!  integer, value :: N
  integer, parameter:: N=10
  type(type1_t) :: A
  integer :: i, N1(1)
  type(type3_t), dimension(:), pointer :: status
  call init_data(A,N)
  print *, A%idx, A%params%idx, A%params%size
  N1(1)=N
  call c_f_pointer(A%status,status,N1)
  do i=1,N
     print *, i, status(i)%idx, status(i)%size
  enddo
end program test_f_to_c
#include
#include
typedef struct TYPE3_T {
    int idx;
    int size;
} type3_t;
typedef struct TYPE2_T {
    int idx;
    int size;
} type2_t;
typedef struct TYPE1_T {
  type2_t params;
  type3_t *status;
  int idx;
} type1_t;
void init_data(type1_t * A, int N) {
  int i;
  A->idx = 1;
  A->params.idx = 10;
  A->params.size = 100;
  A->status = (type3_t*) malloc(sizeof(type3_t) * N);
  for (i=0; istatus.idx = i+1;
    A->status.size = N-i;
[/bash]
Arjen_Markus
You're welcome - I need to get comfortable with iso_c_binding myself too
Arjen
