Dear All,
I have a DLL written in C++ and a program written in Fortran. What I need to do is to transform the Fortran program into a DLL and make the C++ DLL able to call it.
I read several topics on this forum but I am still having trouble: LoadLibrary fails. I don't know if this is a problem due to errors in compiling the Fortran DLL or due to errors in the C++ side.
So far I have:
- Fortran side:
!!!!!PROGRAM MAIN MODULE MAIN USE, INTRINSIC :: ISO_C_Binding USE MODULE_Subs ! This has all the subroutines needed in the program IMPLICIT NONE CONTAINS SUBROUTINE FORTRAN_DLL ( ind_TimeStep, avrSWAP ) BIND (C, NAME='FORTRAN_DLL') !DEC$ ATTRIBUTES DLLEXPORT :: FORTRAN_DLL IMPLICIT NONE INTEGER(C_INT), INTENT(IN) :: ind_TimeStep REAL(C_FLOAT), INTENT(INOUT) :: avrSWAP (*) !!!!! Instructions RETURN CONTAINS !!!!! Some other subroutines used only here !!!!!END PROGRAM MAIN END SUBROUTINE FORTRAN_DLL END MODULE MAIN
- C++ side:
#define _CRT_SECURE_NO_DEPRECATE 1 #define _CRT_SECURE_NO_WARNINGS 1 #include <windows.h> //CED - for external DLL management #include <fstream> HINSTANCE h_FORTRAN_dll; typedef void (*__FORTRAN_DLL)(int, float *); __FORTRAN_DLL FORTRAN_DLL; // Variables for FORTRAN DLL int ind_TimeStep = 1; //avoid mangled names extern "C" { void __declspec(dllexport) __cdecl C_DLL(float *avrSwap, int *aviFail, char *accInfile, char *avcOutname, char *avcMsg); } //Main DLL routine void __declspec(dllexport) __cdecl C_DLL (float *avrSwap, int *aviFail, char *accInfile, char *avcOutname, char *avcMsg) { if (!(h_FORTRAN_dll = LoadLibrary(".\..\Folder\FORTRAN_DLL.dll"))) { printf("\n*** FORTRAN_DLL.dll not found. Aborting.\n"); exit(-1); return; } FORTRAN_DLL = (__FORTRAN_DLL)GetProcAddress(h_FORTRAN_dll, "FORTRAN_DLL"); FORTRAN_DLL(ind_TimeStep, avrSwap ); ind_TimeStep = ind_TimeStep + 1; }
This C++ DLL does not have to do anything but pass avrSWAP(coming from the main program) to the Fortran DLL.
C++ DLL is compiled in release version in Win32 Configuration.
Fortran DLL is compiled in release versione in x86 Configuration.
Any help would be appreciated.
Thank you in advance
Matteo Strada
- « Previous
- 1
- 2
- Next »
Thank you Jim, I'll have a look.
Dear All,
I need your help again.
Now I can successfully load and call the Fortran_DLL.dll whenever the main C++ program needs it.
Now I need to control it better. The original Fortran program is divided in 3 sections:
- Initialization
- First Solution (Solution_0)
- Solution Loop for every time step
What I am trying to do is the following.
Differently from the orginal post, I made some changes. The DLL is no more a MODULE and so the "MainFile.F90" has only the FORTRAN_DLL subroutine:
SUBROUTINE FORTRAN_DLL IF FirstCall THEN Initialization Solution0(Time0) ELSE Solution(CurrentTime) END END SUBROUTINE FORTRAN_DLL
I am able to make DLL aware if it is the first time it is being called or not.
While at the FirstCall the DLL works since it passes from the Initialization subroutine, at the very next call it doesn't work since it has no memory of what has been initializated(i.e. all the parameters read from the input files are no more available). The Initialization subroutine stores all the parameters in a giant TYPE.
So, how can I save in memory this TYPE from the first call? Furthermore I have the constraint that the Initialization subroutine has to be called only once, so I definitely need to save that TYPE. This is because the Initialization subroutine has also the task of opening the output files in order to be written in the 2 Solution subroutines. If I call the Initialization on every call for the FORTRAN_DLL it gives me error.
I am thinking of splitting the FORTRAN_DLL into 2 different subroutines: FORTRAN_DLL_INIT(with Initialization and Solution0) and FORTRAN_DLL (with Solution) but again I need the Initialization TYPE to be stored somewhere.
Thank you in advance.
Matteo Strada
- « Previous
- 1
- 2
- Next »
