Calling Fortran dll from C#
jhlee0301
Hello guys.
I am familiar with C# but need to import Fortran class library. Not expert in Fortran.
This is most popular example in google but I cannot run it.
Dll_test1.dll is located in bin\Debug of C# project.
When executing debug, there occurs format exception error.
My environment is Visual Studio 2019 and Intel Parallel Studio XE 2020.
I think I miss something in compiler environment.
Please help me to find the solution.
Fortran
FUNCTION TSAT11(P)
REAL, INTENT(IN) :: P
REAL :: TSAT11
! Examle calculation
TSAT11 = P - 273.15
RETURN
END FUNCTION
C#
using System;
using System.Runtime.InteropServices;
using System.Windows.Forms;
namespace WindowsFormsApp1
   public static class FortranLib
      private const string _dllName = "Dll_test1.dll";
      [DllImport(_dllName, CallingConvention = CallingConvention.StdCall)]
      public static extern float TSAT11(float P);
   public partial class Form1 : Form
      public Form1()
         InitializeComponent();
      private void btnDoIt_Click(object sender, EventArgs e)
         float p = 300f;
         float t = FortranLib.TSAT11(p);      //<--Error occurs here
Steve_Lionel
You need to "export" the names of procedures you want to call in the DLL. In Intel Fortran, this is done with an ATTRIBUTES DLLEXPORT directive. I also see that the C# code describes the DLL routine as STDCALL.
I think the following will do what you need: add the following line to the Fortran code after the FUNCTION statement:
!DEC$ ATTRIBUTES STDCALL, DLLEXPORT, ALIAS:"TSAT11" :: TSAT11
This has a side effect of making the argument P be pass-by-value.
Steve_Lionel
jhlee0301
Thank you for the solution.
I still have problem in C# WinForm project so I posted new question.
If you have solution for this please review my posting.
https://community.intel.com/t5/Intel-Fortran-Compiler/Call-Fortran-dll-in-C-Winform/m-p/1204526#M151516
