29282 Discussions
Calling Fortran routines contained in modules from C
carlls
Well it seems it is daily post time..... I need to call a FORTRAN subroutine that is defined in a module (as defined below) from a C/C++ calling routine.
Given a F90 source that looks like:
Module MyModule_API
CONTAINS
subroutine my_sub()
print *, 'Hi Dad, Send money!'
stop
end subroutine my_sub
End Module
I create a obj file. When I write my C code as
int call_f()
my_sub();
I get unresolved externalls, so being resourceful I run dumpbin /symbols on the OBJ and see that FORTRAN has mangled the name to MyModule_API_mp_my_sub ... so changing my code to :
int call_f()
MyModule_API_mp_my_sub();
Works, which is good but rather tedious.
Given this data I could write MyModule.h for my C code that has
#define my_sub MyModule_API_mp_my_sub
void MyModule_API_mp_my_sub(void);
But this seems unruly ... is there a better way?
Carl
TimP
Quoting - carlls
Module MyModule_API
CONTAINS
subroutine my_sub()
stop
End Module
Such as subroutine my_sub() bind(c) ? (look up use iso_c_binding)
jimdempseyatthecove
Quoting - tim18
Aproblem with this is the module may name the subroutine in a common manner and therefore several modules may have the same named subroutine (e.g. INIT, FINI, DOWORK, ...). I do suggest the programmer prepend the module name decoration to the function name on the C++ side. The can then choose to either encapsulate the call or use #define to redirect the call. I suppose they could address the C++ standards committee to introduce the Fortran like attribute of ALIAS :~)
Jim Dempsey
carlls
Quoting - tim18
I forgot to mention fornow I am stuck withIFort 9.1, I have IFort 11 but can't use it for this release
Jugoslav_Dujic
Valued Contributor II
Quoting - carlls
Use ALIAS attribute. Even if you want to call the routines from other Fortran units, it will be transparent because it's in module (i.e. has an explicit interface).
[cpp]subroutine my_sub()
!DEC$ATTRIBUTES DECORATE, ALIAS: "my_sub":: my_sub[/cpp]
IanH
Jim Dempsey
Change the binding label of the module procedure on the Fortran side to be unique.
MODULE xxx
CONTAINS
SUBROUTINE INIT, BIND(C, NAME='Really_Unique_Name_To_Specifically_Call_This_Proc_From_C')
(Requires C-interoperability, so not applicable for IVF 9.x)
jimdempseyatthecove
Quoting - IanH
MODULE xxx
CONTAINS
Thanks, that is much better than pre-pending the "MOD_FOO_mp_" to the C++ side as this may be subject to change whereas the BIND(C,NAME="...") will not. Assuming you have the newer IVF (good reason to upgrade eh).
Jim
