29271 Discussions
Calling Fortran subroutine with abstract class
steinberg__elad1
I wish to call a Fortran subroutine from c++. However, one of the arguments in the subroutine is an abstract class. Attached is a simple example of an abstract class, a derived class and the calling subroutine. Is it possible to call such a subroutine from c++? How would I declare and pass the derived class?
module Fabstract
    implicit none
    type, abstract :: arithmetic
    contains
        procedure(a_action), deferred :: action
    end type arithmetic
    abstract interface
    subroutine a_action(this, number, result)
        import :: arithmetic
        class(arithmetic) :: this
        real(8), intent(in) :: number
        real(8), intent(out) :: result
    end subroutine a_action
    end interface
    type, extends(arithmetic) :: multiply
        real(8) :: number_value
    contains
        procedure :: action => multi_action
    end type multiply
    contains
     subroutine multi_action(this, number, result)
        class(multiply) :: this
        result = this%number_value * number
     end subroutine multi_action
end module Fabstract
module Fabstract_use
use Fabstract
implicit none
public :: math_op
contains
subroutine math_op(op, number)
    class(arithmetic), intent(in) :: op
    real(8) :: caluclated_value
    call op%action(number, caluclated_value)
    write(*, *) caluclated_value
end subroutine math_op
end module Fabstract_use
Steve_Lionel
The answer is simple - no, you cannot do this. There is no C (nor C++)  interoperability for Fortran polymorphic entities
steinberg__elad1
Thank you
