29391 Discussions
Calling a C++ dll from a main program in Fortran
iberpar
I'm trying to compile a simple code in Fortran that calls a C++ function which gives the value of two reals. To do so, I have followed the steps:
1. Open an empty console project in C++, add a .h and .cpp files.
(file.h)
#pragma once
#if __cplusplus
extern "C"
_declspec(dllexport) void change_(float* a, float* b);
#endif
(.cpp)
#include "file.h"
#include <iostream>
#include <stdio.h>
extern "C" void change_(float* a, float* b) {
*a = 5.0;
*b = 6.0;
2. Change the project to a .dll type in order to compile it, .lib and .dll were generated.
3. Open a new empty console project in Fortran and add the main code.
(.f90)
program fprog
   real a,b
   a=1.0
   b=2.0
   print*,'Fortran variables:'
   print*,'a=',a
   print*,'b=',b
   call change(a,b)
   print*,'C++ variables:'
   print*,'a=',a
   print*,'b=',b
   stop
end
3. Add the .lib into the source foulder, select the dependency between both projects and compile it, but I get linkage errors.
error LNK2019: unresolved exernal symbol CHANGE which was referred in the funci¢n MAIN__
fatal error LNK1120: 1 unresolved externals
MWind2
New Contributor III
I am not so good at fortran interfaces, but one problem I see is in the dll:
// cxdll.h
#ifdef CXDLL_EXPORTS
#define CXDLL_API __declspec(dllexport)
#else
#define CXDLL_API __declspec(dllimport)
#endif
// This class is exported from the dll
extern "C" CXDLL_API void change(float *, float *);
//cxdll.cpp
// cxdll.cpp : Defines the exported functions for the DLL.
#include "pch.h"
#include "framework.h"
#include "cxdll.h"
#ifdef __cplusplus
extern "C" {
#endif
    // This is an example of an exported function.
    CXDLL_API void change(float* a, float* b) {
        *a = 5.0;
        *b = 6.0;
#ifdef __cplusplus
#endif
and in fortran:
program fcxdll
    implicit none
interface
     subroutine change (f1, f2) BIND(C, name='change')
        use, intrinsic :: ISO_C_BINDING
        implicit none
        type (real) :: f1
        type (real) :: f2
     end subroutine change
end interface
    ! Variables
     real a,b
     a=1.0
     b=2.0
    ! Body of fcxdll
    print*,'a=',a
    print*,'b=',b
    call change(a,b)
    print*,'a=',a
    print*,'b=',b
    stop
    end program fcxdll
 I was using VS2019 and had to put some thngs in fortran project for pre link event:
Additional Dependencies .\$(PlatformName)\$(ConfigurationName)\cxdll.lib
and
Build Events->Pre-Link Event copy ..\$(PlatformName)\$(ConfigurationName)\cxdll.* .\$(PlatformName)\$(ConfigurationName)
mecej4
The name decoration for Fortran external names is compiler-dependent. You seem to be using the conventions of GFortran in your source code, but you are using Ifort to compile.
Change the name in the C file from change_ to CHANGE .
MWind2
New Contributor III
// cxdll.h
#else
#endif
//cxdll.cpp
#include "pch.h"
#include "cxdll.h"
#ifdef __cplusplus
extern "C" {
#endif
        *a = 5.0;
        *b = 6.0;
#ifdef __cplusplus
#endif
and in fortran:
program fcxdll
    implicit none
interface
        implicit none
        type (real) :: f1
        type (real) :: f2
end interface
    ! Variables
     real a,b
     a=1.0
     b=2.0
    ! Body of fcxdll
    print*,'a=',a
    print*,'b=',b
    call change(a,b)
    print*,'a=',a
    print*,'b=',b
    stop
    end program fcxdll
and
iberpar
Thank you for your answers, it worked by changing the function name from change_ to change and adding the Bind C interface into the main Fortran code.
In addition, I had to move the dll to the executabe foulder to make it accesible and set the Fortran project as startup one, if not I was getting a message window saying that the .dll is not a Win32 valid application.
