29487 Discussions
Unable to build project in visual studio
nnem33
I just switched from parallel studio to oneAPI and I am am now unable to build a .vfproj project in visual studio whereas I did not have any such issues with parallel studio. Now I am seeing an attach button instead of build and start. Help is greatly appreciated.
Best,
Nishant.
Steve_Lionel
Which oneAPI installer did you use? You need at least the HPC Toolkit, plus "Intel Distribution for GDB" from the Base Toolkit.
It looks as if the Fortran integration was not installed into your VS. I suggest that you redo the oneAPI installs.
nnem33
Thanks for your reply. I don't know how but I managed to get it to work. I am not sure what the issue was but there was a small update for visual studio 2019 that I installed and it worked.
