29275 Discussions
Calling a C routine from FORTRAN-Links but
camille_dannunzio
Thank you. I made the changes you suggested and it links without errors but in the compile it gives the following syntex errors (in fact when I inserted your piece of code the !DEC lines are in green indicating that they are comment lines. Is this supposed to be?
Camille
C:Exchangeadveds4_15_04graphicsFortranadved_ns-sliceDISPLAY.f
C:Exchangeadveds4_15_04graphicsFortranadved_ns-sliceDISPLAY.f(9) : Info: Syntax error, found IDENTIFIER 'WRITETIFF' when expecting one of:
!DEC$ATTRIBUTES REFERENCE: WriteTiff
C:Exchangeadveds4_15_04graphicsFortranadved_ns-sliceDISPLAY.f(10) : Info: Syntax error, found IDENTIFIER 'FILENAME' when expecting one of:
!DEC$ATTRIBUTES REFERENCE: filename
C:Exchangeadveds4_15_04graphicsFortranadved_ns-sliceDISPLAY.f(11) : Info: Syntax error, found IDENTIFIER 'DESCRIPTION' when expecting one of:
!DEC$ATTRIBUTES REFERENCE: description
fobermaier
try !DEC$ ATTRIBUTES REFERENCE
fobermaier
try !DEC$ ATTRIBUTES REFERENCE ::
