29651 Discussions
Calling a Function from Fortran DLL with Excel VBA
Y__G_
Hello, Everyone.
I am a newbie to VBA calling Fortran DLL.
I need some help getting my Fortran DLL file to work with my Excel VBA.
I am using Windows 7 (X64), Excel 2013 (X64), Microsoft Visual Studio 2015 and  Visual Fortran Composer XE 2013 SP1.
【My FORTRAN code】
Function IntelRho(pi,ti)
    !DEC$ ATTRIBUTES STDCALL,DLLEXPORT::IntelRho
    !DEC$ ATTRIBUTES ALIAS:'IntelRho'::IntelRho
    implicit real(8) (A-H,O-Z)
    real(8) pi,ti,p,t,Intelrho
    p=pi*1000
    t=ti + 273.15
    IntelRho=p/(8.31*t)
    return
End Function Intelrho
【My VBA code】
Public Declare PtrSafe Function Intelrho Lib "D:\Doc\VS2015\Dll2IntelRho\x64\Debug\Dll2IntelRho.dll" (pp As Double, tt As Double) As Double
When I call the function in an Excel cell, such as: I put 3 in Cells(1,1), put 10 in Cells(1,2), then I call the function IntelRho in Cells(1,3) as "=IntelRho(A1,B1)", I got a wrong answer(Cells(1,3)=0). Could anyone tell what the problem is?
Any help is appricated.
Guo
I think you need to add ",REFERENCE" after STDCALL. Have you debugged this to see which values come through to the function?
Y__G_
Thanks for Mr. Lionel's reply! I can see you all around the forum answering all types questions, I think you must be an enthusiastic expert.
I have debugged the DLL as what you said, but when I repeat the process as aforementioned, Excel got crashed and stopped to work, which hinted me about AppCrash event with the Dll2IntelRho.dll.
【My FORTRAN code】
    !DEC$ ATTRIBUTES STDCALL,REFERENCE,DLLEXPORT::IntelRho
    p=pi*1000
    t=ti + 273.15
    IntelRho=p/(8.31*t)
    return
【My VBA code】
----------------no any other statement or code in the VBA.----------
Would you like to sending me some example about Excel VBA calling functions from DLL coded by Intel Fortran?
Thank you very much for your attention!
In the MixedLanguage.zip sample archive that is installed with the compiler you can find a VB_Calls_Fortran sample that is very similar to what you are doing, other than it uses Visual Basic itself rather than VBA from Excel, but the concepts are the same. I suggest you look at that to see how it works.
Y__G_
Hi, Mr. Lionel, I am glad to see your reply.
I have tried the method as exactly as the MixedLanguage.zip, but I still got the incorrect answer as aforementioned in my previous reply. Could you mind analyzing my problem? Thanks for your time!
If you would like me to look at the problem, please attach a ZIP of your VS solution folder with Fortran and Excel files included.
