Calling a Function from Fortran DLL with Excel VBA
Y__G_
Hello, Everyone.
I am a newbie to VBA calling Fortran DLL.
I need some help getting my Fortran DLL file to work with my Excel VBA.
I am using Windows 7 (X64), Excel 2013 (X64), Microsoft Visual Studio 2015 and  Visual Fortran Composer XE 2013 SP1.
【My FORTRAN code】
Function IntelRho(pi,ti)
    !DEC$ ATTRIBUTES STDCALL,DLLEXPORT::IntelRho
    !DEC$ ATTRIBUTES ALIAS:'IntelRho'::IntelRho
    implicit real(8) (A-H,O-Z)
    real(8) pi,ti,p,t,Intelrho
    p=pi*1000
    t=ti + 273.15
    IntelRho=p/(8.31*t)
    return
End Function Intelrho
【My VBA code】
Public Declare PtrSafe Function Intelrho Lib "D:\Doc\VS2015\Dll2IntelRho\x64\Debug\Dll2IntelRho.dll" (pp As Double, tt As Double) As Double
When I call the function in an Excel cell, such as: I put 3 in Cells(1,1), put 10 in Cells(1,2), then I call the function IntelRho in Cells(1,3) as "=IntelRho(A1,B1)", I got a wrong answer(Cells(1,3)=0). Could anyone tell what the problem is?
Any help is appricated.
Guo
Steven_L_Intel1
I think you need to add ",REFERENCE" after STDCALL. Have you debugged this to see which values come through to the function?
Y__G_
Thanks for Mr. Lionel's reply! I can see you all around the forum answering all types questions, I think you must be an enthusiastic expert.
I have debugged the DLL as what you said, but when I repeat the process as aforementioned, Excel got crashed and stopped to work, which hinted me about AppCrash event with the Dll2IntelRho.dll.
【My FORTRAN code】
    !DEC$ ATTRIBUTES STDCALL,REFERENCE,DLLEXPORT::IntelRho
    p=pi*1000
    t=ti + 273.15
    IntelRho=p/(8.31*t)
    return
【My VBA code】
----------------no any other statement or code in the VBA.----------
Would you like to sending me some example about Excel VBA calling functions from DLL coded by Intel Fortran?
Thank you very much for your attention!
Steven_L_Intel1
In the MixedLanguage.zip sample archive that is installed with the compiler you can find a VB_Calls_Fortran sample that is very similar to what you are doing, other than it uses Visual Basic itself rather than VBA from Excel, but the concepts are the same. I suggest you look at that to see how it works.
Y__G_
Hi, Mr. Lionel, I am glad to see your reply.
I have tried the method as exactly as the MixedLanguage.zip, but I still got the incorrect answer as aforementioned in my previous reply. Could you mind analyzing my problem? Thanks for your time!
Steven_L_Intel1
If you would like me to look at the problem, please attach a ZIP of your VS solution folder with Fortran and Excel files included.
