29236 Discussions
Calling a dll made with Fortran by C
patuco
i am getting crazy tying to find out where or why is teh problem in the program I'm doing. If someone could help me, it would be great.
Ill explain you my problem:
i am doing some test to try out how the jni of javaworks. i implemented a dumy program which only purpose is to call a Frotran dll which has to show on the screen the typical Hello world. I did the C++ wrapper using the visual studio .net. Ive already accomplished the communication between the wrapper and Java. in a second stage I try to do the same but with the wrapper calling the fortran dll, and here is where the problems occur: the function called by the wrapper located in the fortran dll is not "found":
ReadValue error LNK2019: smbolo externo _PRINTER@0 sin resolver al que se hace referencia en la funcin "long __stdcall Java_ReadValue_getValue(struct JNIEnv_ *,class _jobject *)" (?Java_ReadValue_getValue@@YGJPAUJNIEnv_@@PAV_jobject@@@Z)
The Fortran code is as follows:
INTEGER FUNCTION PRINTER()
!decs attributes c :: PRINTER
!MS$ATTRIBUTES DLLEXPORT,STDCALL,ALIAS:'PRINTER'::PRINTER
WRITE(6,'("-- FORTRAN funcion printer --")')
PRINTER=2
END
as you can observed is quite obvious.
So as the wrapper:
#include "stdafx.h"
#include "stdio.h"
#include "ReadValue.h"
#include "jni.h"
extern "C" __stdcall int PRINTER();
// i even try with : extern "C" __cdecl int PRINTER();
JNIEXPORT jint JNICALL Java_ReadValue_getValue(JNIEnv * env, jobject jobj)
printf("-- A ver si funciona la referencia -- ");
int result = PRINTER();
printf(" -- valor de retorno ke leyo del archivo -- ",result);
return result;
Anyone can help me?? Thanks.
patuco
i have a problem, i should be doing something terrible because i.m getting an exception from the java virtual machine. Im trying the dll to return to the java a String so im doing like follows:
wrapper:
JNIEXPORT jstring JNICALL Java_Main_get_1name(JNIEnv *env, jobject jobj, jint param)
char buf[80];// = (char*)malloc(num_chars);
strcpy(buf, Getname(param +1));
return js;
and the fortran:
CHARACTER(80) FUNCTION GETNAME(VALUE)
!MS$ATTRIBUTES DLLEXPORT,C,ALIAS:'_Getname'::GETNAME
INCLUDE 'COMMON.LVG'
INTEGER VALUE
WRITE(*,*) "The VALUE is ", MOL(VALUE)
GETNAME=MOL(VALUE)
END FUNCTION
and the error comes where the fortran call is located. :?
# An unexpected error has been detected by HotSpot Virtual Machine:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x02cb4c7c, pid=2804, tid=1748
# Java VM: Java HotSpot Client VM (1.5.0_06-b05 mixed mode, sharing)
# Problematic frame:
# C [mlvg.dll+0x14c7c]
# An error report file with more information is saved as hs_err_pid2804.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Anyone could give me a clue? Thanks.
Message Edited by patuco on 02-07-2006 01:17 AM
Steven_L_Intel1
I am absolutely certain that what Java wants to see for a function returning a string isn't what Fortran provides.
In Intel Fortran, a function that returns a CHARACTER value has the return variable passed as a hidden first argument, as if it were a subroutine with an extra character argument. That also affects where the string lengths are.
Also, do you know for certain that Java wants to call routines using the C calling mechanism and not STDCALL?
patuco
hi,
i'm sure i need the c cuz the test i did showing on the screen the value worked. It is something related with the returning value, i will try what Jugoslav suggested days befor, passing the array as parameter, but my goal was trying to avoid it.
patuco
and of course what java expect is not what fortran provides... but that is one of the purpose of the wrapper: it receives a char * from Fortran and it will transform it into an String for Java.
The point is that ive never used the type CHAR(80), is something i found looking through the help, so i do not know how can i implement a function in fortan which returns a variable which contains only characters.
Jugoslav_Dujic
Valued Contributor II
subroutine GetName(name)
!DEC$ATTRIBUTES whatever
CHARACTER(*) name
name = ...
name = trim(name)//char(0)
end subroutine GetName
extern "C" Getname(char*, int)
Getname(buf, 80)
patuco
Hi everyone,
Ive been trying to copy the string in the fortran code (it is equivalent as C123TE) in the wrapper but I could accomplish it.
The wrapper calls the native as follows:
Declaration
extern "C" __declspec(dllexport) char* Getname(char *,int );//_Getname
Implementation
char *buf = (char*)malloc(80);
buf = " ";
printf("Before calling the wrapper: %s ",buf);
//char buf[80];
printf(" --C Calling the native ");
Getname(buf, param);
printf("%s ",buf);
printf("-- C Return form the native->buf: ", buf);
return env->NewStringUTF(buf);
The fortran is as follows (names of the variables are unsignificant):
Mol is an array of chars which combines signs and numbers with values like: CE23R, O89R, R4576,23R45.
SUBROUTINE GETNAME(ARRAKY, VALUE)
!MS$ATTRIBUTES DLLEXPORT,C,ALIAS:'_Getname'::GETNAME INCLUDE ''COMMON.LVG'
INTEGER VALUE
CHARACTER*(*) ARRAKY
WRITE(*,*) "The INPUT is ", ARRAKY
WRITE(*,*) "The FORTRAN is ", MOL (VALUE)
ARRAKY= MOL (VALUE)
ARRAKY = TRIM(ARRAKY)
WRITE(*,*) "The ARRAKI is ", ARRAKY
END SUBROUTINE GETNAME
Output:
--C -- Calling the native
The INPUT is h
The FORTRAN is C17B
The ARRAKI is C
-- C Return form the native:
As you can observed only the first character is copied. :?
I`ve tried using an auxiliar char* and using a line like :
AYU(1:10)=MOL(VALUE)(1:10)
being the string copied into AYU ok but not in one passed as parameter:
ARRAKY(1:10)=AYU(1:10)
so as in the wrapper defining a static array (buffer[80]) but getting the same results.
Do you have any idea or suggestion? Thanks.
Message Edited by patuco on 02-07-2006 01:15 AM
Message Edited by patuco on 02-07-2006 01:18 AM
Jugoslav_Dujic
When a string argument appears in Fortran code, it is "transcribed" as two arguments in C. One is char* (argument address) and the other is int (buffer length). By default, the latter is passed at the end of argument-list.
So, for the given Fortran routine, the C prototype should be:
char* Getname(char* string, int value, int stringlen);
Stringlen should be 80 in this case, obviously. Also, you should append a char(0) to the Fortran string, so that it can be parsed correctly in C:
ARRAKY= TRIM(MOL(VALUE))//CHAR(0)
patuco
hi,
ive tryed your suggestions but i do not get what i am not considering,because the same behaviour is produce, i mean, the fortran code is parse:
c!MS$ATTRIBUTES REFERENCE :: ARRAKY
INTEGER VALUE
WRITE(*,*) "The FORTRAN is ", MOL(VALUE)
being call in the way:
extern
"C" __declspec(dllexport) char* Getname(char * ,int ,int );
//string, str_length, element
buf = " ";
Getname(buf, 80,80);
printf("%s",buf);
//strcpy(buf, Getname(param,aux));
but the results arelike before:
The INPUT is h //???
The FORTRAN is OH
The ARRAKI is O //?????
patuco
Adding some comments to my previous subject is that i was performing some tests and getting all teh time the same result, only the first character is copied:
extern
"C" __declspec(dllexport) char* Getname(int * value, char * string, int * stringlen);//_Getname
char
*buf = (char*)malloc(10);
Getname(&parameter, buf, &i);//parameter = i = 10
SUBROUTINE GETNAME(VAL, ARRAKY)
CHARACTER (*)ARRAKY
ARRAKY="ayudaaa"
WRITE(*,*) "The INPUT is? ", ARRAKY
And another point, after leaving the fortran code the value is not saved (for the moment only one character)!!!!! I thought iwas passing the parameter by reference.
Message Edited by patuco on 02-07-2006 05:05 AM
patuco
Adding to the last comment, after leaving the fortran dll the value of the char^* is not saved, when i thought i was passing it by reference ????
Jugoslav_Dujic
buf should go by reference, but not buflen. Remove the *.
Jugoslav_Dujic
...also, DEC$ATTRIBUTES C implies call-by-value for scalar arguments (but not for strings and arrays). !DEC$ATTRIBUTES C, REFERENCE implies call by reference. However, hidden string length is never passed by reference.
patuco
before trying
extern "C" __declspec(dllexport) char* Getname(int *molecule, char * string, int *stringlen);//_Getname
i tryed with
extern
"C" __declspec(dllexport) char* Getname(int molecule, char * string, int stringlen);//_Getname
but getting the same result, on ly the first char is copied and what i found after leaving the fortran it is not actualized. Could it be the C decalaration, so instead of it i should used stdcall?
I am getting crazy.... i do not know what is going on with this char *???
By the way, thanks a lot for your help ok?
Jugoslav_Dujic
I forgot it's CVF 6.0, not IVF. In CVF, the string length comes immediately after string, not at the end of the list. Thus,
extern "C" __declspec(dllimport) void
Getname(int molecule, char* string, int stringlen);//_Getname
is paired with
subroutine Getname(molecule, string)
!DEC$ATTRIBUTES C, DLLEXPORT, ALIAS:"_Getname":: Getname
integer molecule
character(*) string
WRITE(*,*) LEN(string)
patuco
I tryed your suggestion and i get a result which makes mescare.
Output
1
he INPUT MOLECULE is? |
Using only LEN to obtain the length of the array passed is only 1 !!??
i think the parameter definition and implementation is ok, isnt it?
extern
"C" __declspec(dllimport) void Getname(int molecule, char * string, int stringlen);
Implementation
int i = 15;//length of the vector
int parameter = 5;//to access the 5th element in fortran
char *buf = (char*)malloc(i);
buf = " ";
printf("--C-- buffer: %s ",buf);
Getname(parameter, buf, i);
printf(" -- C --REturned buf: %s ", buf);
jstring jstrBuf = env->NewStringUTF(buf);
return jstrBuf;
by the way, why instead fo dllexport, dllimport??
i tryed another test and the same
CHARACTER (*)ARRAKY
ARRAKY="ayudaaa"
ARRAKY= TRIM(ARRAKY)//CHAR(0)
WRITE(*,*) LEN(ARRAKY)
write(*,*) "The INPUT MOLECULE is? ", ARRAKY
output:
1
The INPUT MOLECULE is? a
patuco
adding to the last comment where i explain the results obtained
i am trying another thing using de atributes value and reference, as follows:
!MS$ATTRIBUTES VALUE :: VAL
CHARACTER *48 ARRAKY
cARRAKY="ayudaaa"
cARRAKY= TRIM(ARRAKY)//CHAR(0)
now the output of the length is what i specified in the declaration !!????
and another thing is that each time i tryed to copy values im gettin an error.
patuco
eventhough defininig the buffer as :
const int i = 15;
char buf;
the output is the same as i commented:
--C--buffer:
--C --Calling native
1
The INPUT MOLECULE is? ?
Jugoslav_Dujic
The next-to-last version looks OK. You shouldn't hard-code string length in Fortran, as in the last version that "overrides" the length passed by caller, and you can easily end up overwriting something that you shouldn't.
Sorry, I can't spot anything wrong with the next-to-last version.
patuco
which of the versions are you talking about? i paste a couple and i don`t get why all the time the length of the parameter is 1
Jugoslav_Dujic
Never mind. My bad I thought that !DEC$ATTRIBUTES C does not affect how string arguments are passed; however, it does... grrr...
It appears that !DEC$ATTRIBUTES C also implies that strings are passed by value (!). I don't know why on Earth would anyone want to do that, but that's how it's implemented.
So, you should specify REFERENCE for the string argument, and pass the length explicitly:
 SUBROUTINE GETNAME(VAL, ARRAKY, iLen)
!MS$ATTRIBUTES REFERENCE:: Arraky
INTEGER val
CHARACTER(iLen) ARRAKY
ARRAKY="ayudaaa"
Getname(int molecule, char* string, int len);
Btw, __declspec(dllimport) is needed (but can be omitted) because you're importing the symbol from another dll.
Steven_L_Intel1
MS did it that way so DVF followed suit.
