!decs attributes c :: PRINTER
!MS$ATTRIBUTES DLLEXPORT,STDCALL,ALIAS:'PRINTER'::PRINTER
WRITE(6,'("-- FORTRAN funcion printer --")')
PRINTER=2
END
#include "stdafx.h"
#include "stdio.h"
#include "ReadValue.h"
#include "jni.h"
extern "C" __stdcall int PRINTER();
// i even try with : extern "C" __cdecl int PRINTER();
JNIEXPORT jint JNICALL Java_ReadValue_getValue(JNIEnv * env, jobject jobj)
printf("-- A ver si funciona la referencia -- ");
int result = PRINTER();
printf(" -- valor de retorno ke leyo del archivo -- ",result);
return result;
Anyone can help me?? Thanks.
- « Previous
- Next »
If it just status you want, then I agree with Steve about message boxes. Here is a trimmed-down example of your formatted message as it would appear and here is the code
character(256) message character*24 chain, crlf*2 real*8 mua,mub,muc,colden chain='abcdefghijklmnopqrstuvwx' mua=1.0d+00 mub=2*mua muc=3*mua colden=1.0d-10 crlf=char(10)//char(13) write(message,2001)crlf,chain,crlf,mua,crlf,mub,crlf,muc,crlf,colden,crlf 2001 FORMAT(1X,24('*'),a2, & ' chain = ',A24,a2, & ' Mua = ',1PG10.4,' D',a2, & ' Mub = ',1PG10.4,' D',a2, & ' Muc = ',1PG10.4,' D',a2, & ' COLUMN DENSITY = ',1PG10.4,' CM-2',a2, & 1X,24('*')) ret=MESSAGEBOX(ghWndMain, message//''c,& 'Test of Output'C, & MB_ICONEXCLAMATION .OR. MB_OK)
use ifwin
in there to make the MessageBox and MB_xxx symbols available.
by the way an easy question
how can i write the messages into a file?, i mean ive never had worked with files so i hav no clue how to create, open,write and close them
My Lord, you're still using Microsoft Fortran PowerStation 4.0 ?! It's not a problem if it suits you well, but note that it's 10 years old (and one of buggiest compilers I've seen).
The pipes sample might work if you USE MSFWIN instead, but I can't offer any guarantees on FPS4.0. It had a rather incomplete set of API translation, and I can't tell whether the call prototypes are compatible with IVF ones. Basically, you only need to redirect stdin to "read" end of the pipe (read from C/Java) and stdout to "write" end (fortran WRITE). However, it's still questionable whether it will work. If you can't get simple WRITE to write to the console, it's unlikely to work for a pipe –' the issue is when Fortran run-time library "associates" the STD_OUTPUT_HANDLE with WRITE(*) stream, and whether it looks up to it later. If the association happens at dll load time, you can't prevent it (except perhaps by redirecting first from C and then calling LoadLibrary/GetProcAddress).
hi
i am trying to use some of the code you did in the pipe to test how it works, but i am getting some troubles:
!code form Jugoslav
INTEGERiStdoutWr, iStdoutRd,iret
TYPE(T_PROCESS_INFORMATION):: PI1
TYPE(T_STARTUPINFO):: SI1
TYPE(T_SECURITY_ATTRIBUTES):: SA1
SA1.nLength = sizeof(SA)
SA1.bInheritHandle = TRUE
SA1.lpSecurityDescriptor = NULL
iret = CreatePipe(LOC(iStdoutRd), LOC(iStdoutWr), SA, 0)
iret = SetHandleInformation( iStdoutRd, HANDLE_FLAG_INHERIT, 0)
SI1.cb = sizeof(SI1);
SI1.hStdError = iStdoutWr
SI1.hStdOutput = iStdoutWr
SI1.dwFlags = STARTF_USESTDHANDLES
PI1 = T_PROCESS_INFORMATION(0, 0, 0, 0)
iret = SetStdHandle(STD_OUTPUT_HANDLE, iStdInWr)
WRITE(*,*) 'Prueba'
iret = CloseHandle(iStdoutWr)
iret = CloseHandle(iStdoutRd)
iret = CloseHandle(PI1.hProcess)
iret = CloseHandle(PI1.hThread)
i am becoming some errors:
1. i have changed the names adding 1 because it sayd multiple type declarations for symbol PI
2. with this lines i am getting this two errors:
error FOR2290: implicit type for ISTDINWR
error FOR2290: implicit type for SIZEOF
3. where is it written? i mean in order to tell java where to read??
Thanks for your help
//C wrapper
#include "windows.h"
HANDLE hReadEnd, hWriteEnd;
CreatePipe(&hReadEnd, &hWriteEnd, NULL, 0);
SetStdHandle(hWriteEnd, STD_OUTPUT_HANDLE);
SetStdHandle(hReadEnd, STD_INPUT_HANDLE);
However, forget about the idea if you're using single-threaded exe, even if you succeed in redirecting I/O to the pipe, you cannot simultaneously WRITE on Fortran side and ReadPipe on C side. Pipes example uses two processes which run concurrently, so one can wait for the other to complete I/O operation and display the output as soon as it's done. In your case, you could only display the pipe contents after Fortran has finished.
man i owe you a couple drinks, thanks for the help,
but please tell me that there is a way in java using this editor, to write a file besides open an unit and write on it, because it makes me change a lot of lines that are done as write(*,*) and i really hate this kind of work
i was performing some tests to learn how to use AllocConsole, but the repplies werent so good as I expected. The wrapper is creating a console in order to show the printf and write messages (from the Fortran and of course the own library). I am creating it as follows:
JNIEXPORT
void JNICALL Java_Main_console(JNIEnv *env, jobject jobj){
static const WORD MAX_CONSOLE_LINES = 500; int hConHandle; long lStdHandle;CONSOLE_SCREEN_BUFFER_INFO coninfo;
FILE *fp;
// allocate a console for this appAllocConsole();
// set the screen bufferGetConsoleScreenBufferInfo(GetStdHandle(STD_OUTPUT_HANDLE), &coninfo);
coninfo.dwSize.Y = MAX_CONSOLE_LINES;
SetConsoleScreenBufferSize(GetStdHandle(STD_OUTPUT_HANDLE), coninfo.dwSize);
// redirect unbuffered STDOUT to the console
lStdHandle = (
long)GetStdHandle(STD_OUTPUT_HANDLE);hConHandle = _open_osfhandle(lStdHandle, _O_TEXT);
fp = _fdopen( hConHandle, "w" );
*stdout = *fp;
setvbuf( stdout, NULL, _IONBF, 0 );
// redirect unbuffered STDIN to the consolelStdHandle = (
long)GetStdHandle(STD_INPUT_HANDLE);hConHandle = _open_osfhandle(lStdHandle, _O_TEXT);
fp = _fdopen( hConHandle, "r" );
*stdin = *fp;
setvbuf( stdin, NULL, _IONBF, 0 );
// redirect unbuffered STDERR to the consolelStdHandle = (
long)GetStdHandle(STD_ERROR_HANDLE);hConHandle = _open_osfhandle(lStdHandle, _O_TEXT);
*stderr = *fp;
setvbuf( stderr, NULL, _IONBF, 0 );
// point to console as wellios::sync_with_stdio();
printf("I did it! ");
cout << "Hello"
Please any idea why is not any message shows?
thanks
int APIENTRY WinMain(HINSTANCE hInstance,
HINSTANCE hPrevInstance,
LPSTR lpCmdLine,
int nCmdShow)
//create the console
startConsoleWin();
JNIEXPORT void JNICALL Java_Main_console(JNIEnv *env, jobject jobj)
//call the api????
printf("1 ");
Message Edited by patuco on 02-22-2006 03:10 AM
Sorry for having to make such disclaimers, but I really can't offer much help regarding Java setup, and tell why the concrete code doesn't work. There are too many low-level issues involved. You can also try some Java-related group comp.os.ms-windows.programmer.win32 on groups.google.com.
do not worried about the disclaimers, it is normal and happens a lot.
Just a question to know your opinion after reading again what you said about pipes in some posts before.
Will be possible to use pipes to write the outputs of the librariy to a file? (I am asking it because i know how to use pipes in java, and this option wont make me change the fortran files, which as i supposed you suspect are not implemented for me, besides the fact i should review and correct them).
- « Previous
- Next »
