29348 Discussions
Calling type bound procedures on derived type components trashes data
MDK
[plain]module data_type
    implicit none
    type :: data_t
        integer :: val = -1
    contains
        procedure :: set
    end type
contains
    subroutine set(this, val)
        implicit none
        class(data_t), intent(out) :: this
        integer, intent(in) :: val
        this%val = val
    end subroutine
end module
module container_type
    use data_type
    implicit none
    type :: container_t
        type(data_t) :: data1
        type(data_t) :: data2
    contains
        procedure :: set_good
        procedure :: set_clobber
        procedure :: print => print_container
    end type
contains
    subroutine set_clobber(this, val)
        implicit none
        class(container_t), intent(out) :: this
        call this%data1%set(val)  ! TBP call: bad!
        call this%data2%set(2*val)
    end subroutine
    subroutine set_good(this, val)
        implicit none
        call set(this%data1, val)  ! regular call: ok
        call set(this%data2, 2*val)
    end subroutine
    subroutine print_container(this)
        implicit none
        class(container_t), intent(in) :: this
        write (*, *) this%data1%val, this%data2%val
    end subroutine
end module
program ifort_bug
    use container_type
    implicit none
    type(container_t) :: x
    call x%set_good(-3)
    call x%print()
    call x%set_clobber(10)  ! data2 gets written to data1
    call x%print()
    read (*, *)  ! pause
end program[/plain]
This might be related to a previous bug (<>), but this doesn't involve procedure pointers. This is with 11.1.054, which I just downloaded today.
If you have one derived type that contains derived type components, calling type-bound procedures on the components will clobber the values of other components. In the example above, attempting to set the value of 'data2' using a TBP will change the value of 'data1' instead. The workaround is to use regular calls--'set(data2, val)' instead of 'set(data1, val)'--but this gets increasingly undesirable as you start working with multiple derived types across several modules.
Thanks - we'll look into this.
I believe this is a different problem, the issue ID is DPD200148795. What appears to be happening is that in set_clobber, the compiler is passing set_clobber's THIS as the THIS argument to set rather than the individual data1 and data2 components. Thanks for letting us know of the problem.
abhimodak
May be this is related to what Steve said but just an FYI:
I find that when stepping through the debugger the values shown for the components are messed up. This is true even when the results are not "messed up". On the other hand, printing the values in the set* subroutines do show them correctly.
Abhi
Lorri_M_Intel
Quoting - abhimodak
Abhi
Dummy arguments that are CLASSes do not display correctly in the debugger. We know (really!) and are working on fixing that.
Sorry for the inconvenience --
- Lorri
The problem reported in this thread (wrong results) is expected to be fixed in Update 5, due late this month (or maybe early Feb.)
