Several of the newer development systems I've worked with allow you to do this, just wondering if this is possible with this compiler.
Thanks in advance!
This is true even if I go to project properties -> Linker ->Input, there is an entry for "Embed Managed Resource File", and put the name of my file in there, but I can't get it to incorporate the file.
I'm also asking questions on a .NET forum, but they are blaming the extensions. Is there anyplace I can get help with the Intel extensions?
There is not a different forum, but you are using an unsupported version of the compiler that was replaced more than three years ago. I have not used 7.1 in a long time, but I don't recall a problem adding a version resource. I'd expect that what you would do is Project..Add to Project..Resource File. Then double-click on the resource.rc file to open the resource editor.
If that doesn't work, then I would suggest updating to Intel Visual Fortran 9.1, where I know this works.
Well, I have CVF 6.6C that uses DevStudio and I tried this on a simple console .EXE that initially had no resources.
I went to Insert..resource, selected 'Version' from the list of resources, saved the resource in 'script1.rc' and added it to my project. I then compiled the resource file 'script1.rc' and then built the .EXE.
When I left mouse click on the .EXE file, and select 'Properties' a Properties window opens and the version tab is there. Where's the problem?
