29636 Discussions
Can a Linux server host a MAC OS compiler file
Dave_A__from_Lifeboa
Customer asks " I know compilers are OS specific. Can a Linux server (license server) host a MAC OS compiler file?
Thanks..
Dave A. from Lifeboat Distribution.
Ron_Green
If I understand the question: Yes, you should be able to set up an NFS export from the Linux server, mount it on the Mac, and install the compiler to this shared filesystem. The one caveat is that the Xcode integrations would probably still be done on the local /Developer filesystem, unless that too was an NFS export from the linux server.
Now if the user is asking if an executable built with the Mac compiler can run on linux, the answer is no. the binaries and executables created will only run under Mac OS X.
ron
