Can a function return an array?
Carsten_A_
Is it possible to return an array via function?
I tried following
program test
    !dec$ attributes dllimport :: Vector
    implicit none
    real(8), dimension(2) :: dir, Vec, newVec
    dir = [3, 5]
    newVec = Vec(dir)
    print*, newVec
    pause
end program
function Vector(direction)
    !dec$ attributes dllexport :: Vector
    implicit none
    real(8), intent(in), dimension(2) :: direction
    real(8), dimension(2) :: Vector
    Vector = direction * 2
end function
I get the error:
Subscript #1 of the array VEC has value 3 which is greater than the upper bound of 2
What am I doing wrong?
FortranFan
You can also consider code along the following lines:
MODULE m
   USE, INTRINSIC :: ISO_FORTRAN_ENV, ONLY : R8 => REAL64, I4 => INT32
   IMPLICIT NONE
   PRIVATE
   PUBLIC :: Vector
CONTAINS
   PURE FUNCTION Vector(direction) RESULT(NewVec)
      !.. Argument list
      REAL(R8), INTENT(IN) :: direction(:)
      !.. Function result
      REAL(R8), DIMENSION(SIZE(direction)) :: NewVec
      NewVec = direction * REAL(2, KIND=R8)
      RETURN
   END FUNCTION Vector
END MODULE m
PROGRAM p
   USE m, ONLY : Vector
   IMPLICIT NONE
   !.. Local variables
   REAL(R8), DIMENSION(2) :: dir, newVec
   dir = [3, 5]
   newVec = Vector(dir)
   PRINT *, "newVec = ", newVec
   STOP
END PROGRAM p
Also, see Dr Fortran's blog at https://software.intel.com/en-us/blogs/2013/12/30/doctor-fortran-in-its-a-modern-fortran-world.  As you may be well aware, Dr Fortran's blogs in general and the various books references in the particular blog on modern Fortran all point out to your benefit the various aspects including:
  • the benefit of using MODULEs, especially in terms of providing interface information on procedures, code readability, access control, information hiding, etc.
  • the various KIND, SHAPE, RANK features available in the language standard with various INTRINSIC modules (ISO_FORTRAN_ENV) and kinds (REAL64, INT32, etc.) and SIZE function that allows one to write portable as well as flexible code (notice how the function Vector in above snippet is not restricted to a dimension of 2),
Also, I suggest looking at Quote #5 in this post (https://software.intel.com/en-us/forums/topic/486623) about the option of .DEF files if you want to include your functions such as Vector in a DLL: this can be an alternate option to including the !DEC$ directives in the code which requires additional attention with respect to code portability in addition to causing code clutter (in the eyes of some).
mecej4
You probably meant to write "vector" where you wrote "vec" at two places in the main program.
A function that returns a array should be given an explicit interface in the caller. That is what the compiler is grumbling about, but in a roundabout way.
jimdempseyatthecove
What you have done is something analogous to a gather statement (using an array of indicies)
Vec(dir) is equivalent to [Vec(dir(1)), Vec(dir(2))] which is equivalent to [Vec(3), Vec(5))]
Jim Dempsey
For more info on explicit interfaces, see Doctor Fortran Gets Explicit - Again!
FortranFan
MODULE m
   IMPLICIT NONE
   PRIVATE
   PUBLIC :: Vector
CONTAINS
      !.. Argument list
      !.. Function result
      RETURN
   END FUNCTION Vector
END MODULE m
PROGRAM p
   IMPLICIT NONE
   !.. Local variables
   dir = [3, 5]
   STOP
END PROGRAM p
Carsten_A_
I put the function in a module and it works fine!
Thanks at all!
