problem mpi
Mouhamad_A_
Dear all,
 I am trying to compile the following program, using ompi compiled with intel,
mpif90 -c -convert native -m64 -O3 -mieee-fp -m64 PLM.F90
mpif90 -o a.out PLM.o /work/crct/mo9378al/sources/arpege-climat/build-5.2-ompi-intel/packs/502_main.00.MPIINTEL.x/lib/libxrd.local.a /work/crct/mo9378al/arpege-5.2/ompi-intel/lib/libgribex.a
but I get the following error.
 ///// LFIOUV - Unite logique  7, facteur multiplicatif lu sur fichier= 12, attendu=  6
 ///// LFIOUV - Nom='restart'
 ///// LFIOUV - Nom SYSTEME='/panfs/carterfs.u-bourgogne.fr/work_crct/mo9378al/Compute_restart_intel/restart'
 ///// LFIOUV - On essaie de s'adapter au facteur multiplicatif lu sur le fichier...
 ///// LFIOUV - Unite  7 OUVERTE, derniere Modification OK a 20111013_164658,    293 Articles de donnees,  2058240 mots en tout
 */*/* FAITOU - KREP= -60, KNUMER=  7, LDNOMM= T, CDSTTU='    OLD', LDERFA= T,  LDIMST= F, KNIMES= 1, KNBARP=     0 KNBARI=   293
 ***** FAITOU - CDNOMC='Cadre.rest'
 ***** FAITOU - UN ARTICLE DU CADRE EST MANQUANT, UNITE  7                *****
I thing it is a problem of little/big endian.
Could you please tell me if the command I have missed something in the compilation ?
Thank u a lot for your help
regards
Mouhamad
TimP
If the file will always be big-endian, you could use the Intel-specific syntax for that in the OPEN, or you could pass the corresponding environment variable to each rank....
The options you passed to mpif90 appear to pertain to pgi Fortran.  If you meant -convert big-endian, you should consult the compiler documentation.  If ifort doesn't recognize the ieee-fp option, ifort options in that area include -fp-model precise, -prec-div -prec-sqrt, -assume protect_parens.....
Mouhamad_A_
Dear Tim Prince,
 Thanks a lot for your reply.
 I am going to try what you have suggested me.
Thanks again
Mouhamad
TimP
Compile option -convert big_endian would apply to all data files.  Apparently, according to the table entitled "OPEN Statement specifiers" in the compiler html reference, native would be the same as little_endian.
