I get this link error when building an existing project.
"Link: error: could not find 'link' "
It was working fine and I know of nothing that changed. Seems like it refers to VC libraries?
I also see reference on Intel website:
http://www.intel.com/support/performancetools/fortran/windows/sb/cs-007858.htm
But no information on corrective actions?
Any suggestions?
Ken
Steve, Thank you for replying especially on a Sunday.
I have been using this for a few years. I have visual studio 2003 .net and Intel v9.
I t was working fine two weeks ago.
Ken
------ Build started: Project: fgtaz_6-7-06, Configuration: Debug|Win32 ------ Linking... Creating temporary file "RSP1.rsp" with contents [ /OUT:"C:Documents and SettingskenMy DocumentsBoehm work monitor 2008Monitor_1-18-08GTAnalysisfgtaz.dll" /INCREMENTAL:NO /NOLOGO /DEBUG /PDB:"Debug/fgtaz_6-7-06.pdb" /SUBSYSTEM:WINDOWS /IMPLIB:"Debug/fgtaz_6-7-06.lib" /DLL Debug/util_splnq1.obj Debug/gta_calc_humidity_102604.obj Debug/gp_utherm_2102.obj Debug/gp_gauss.obj Debug/crvfit_main_mod_12-02-06.obj Debug/crvfit_lsqpol.obj Debug/gta_cooling_estimate_21506.obj Debug/gp_seten_2102.obj Debug/gp_efmt.obj Debug/crvfit_xum.obj Debug/crvfit_regpts.obj Debug/util_xlinr2.obj Debug/util_unilini_010904.obj Debug/gta_main_prop_interface_120105.obj Debug/gp_blockdata.obj Debug/util_double_dbin_r3.obj Debug/gta_airflow_estimate_61103.obj Debug/gp_tranp.obj Debug/gp_search_datar_2102.obj Debug/crvfit_deltas_8-12-06.obj Debug/gta_steam_data.obj Debug/gta_calc_new_wtfrac.obj Debug/gp_cphs.obj Debug/crvfit_deltaregpts.obj Debug/gp_out1_2102.obj Debug/util_tlook.obj Debug/gta_effic_polytropic_052605.obj Debug/gp_utran_varfmt.obj Debug/gp_matrix_2102.obj Debug/gp_tranin_2102.obj Debug/gp_react_41502.obj Debug/crvfit_datapackager_1-20-08.obj Debug/gp_thermp.obj Debug/gta_prepare_props_052605.obj Debug/gp_eqlbrm_2102.obj Debug/gp_newof.obj Debug/FGTAZ_online_analysis_1-20-08.obj Debug/DllMain_2-9-06.obj Debug/Errlog.obj "C:Documents and SettingskenMy DocumentsBoehm work monitor 2008FGTAZ dll projectcgtaz_new_assumptions_add_loop_12-28-07mtrxdebugmtrx.lib" ] Creating command line "Link @"C:Documents and SettingskenMy DocumentsBoehm work monitor 2008FGTAZ dll projectcgtaz_new_assumptions_add_loop_12-28-07fgtaz_6-7-06DebugRSP1.rsp"" Link: executing 'link' Link: error: could not find 'link' fgtaz_6-7-06 build failed.
Its 32 bit
The ifort setup should use the vcvars32.bat (or similar) from the Microsoft installation to add those paths. They should be present when you open the Fortran command line window.
Some possibilities:
Perform a repair on your Intel Fortran installation; This should have a good chance, if it was working before.
Add the full path to the folder including the Microsoft link.exe in the ifort.cfg in your Fortran installation. This is needed, if some software not foreseen by the Fortran installer has changed the PATH in such a way that the Microsoft PATH items don't come in the correct sequence.
Mystery Solved!
After reading the suggestions I recalled running registry checker and each time it comes up with bad path for the following:
[HKEY_CURRENT_USERSoftwareMicrosoftVisualStudio7.1Intel FortranVFToolOpt9090IA32]
"BinDir"="$(IFORTInstallDir)Bin;C:Program FilesCommon FilesIntelShared FilesIA32Bin;$(VCInstallDir)bin;$(VSInstallDir)Common7ToolsBin;$(VSInstallDir)Common7Tools;$(VSInstallDir)Common7ide;C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem"
[HKEY_CURRENT_USEREnvironment]
"LIB"="c:Program FilesMicrosoft Visual Studio .NET 2003v7Lib"
Apparently it had removed them. I resolred that days backup and it now works.
Not sure why they are considered bad paths?
Ken
The moral here is don't delete anything in the registry that you don't understand.
