29423 Discussions
Can anyone explain how to store a value returns by a linux command in a fortran local variable...
Madhubalan_R_
Can anyone explain how to store a value returns by a linux command in a fortran local variable without using IO operations.
The standard Fortran intrinsic EXECUTE_COMMAND_LINE does this.
An example:
integer stat
call EXECUTE_COMMAND_LINE('ls',EXITSTAT=stat)
For Intel Fortran this will require compiler version 15.0.1 or later.
Madhubalan_R_
Thanks Mr.Steve.But if I want to store the output of the linux command 'whoami' in a fortran variable,What should I do?
Ah, you want to save the output. There's no way I know of to do this without using I/O. However, for this particular purpose I think that the POSIX subroutine PXFGETLOGIN might do what you want.
PXFGETLOGIN
POSIX Subroutine: Gets the name of the user.
Module
USE IFPOSIX
CALL PXFGETLOGIN (s,ilen,ierror)
s
(Output) Character. The returned user name.
ilen
(Output) INTEGER(4). The length of the string stored in s.
ierror
(Output) INTEGER(4). The error status.
If successful, ierror is set to zero; otherwise, an error code.
