TARGET question
Adrian_F_1
I have some code which is supposed to set up a structure foo of type t_stuff.  This type contains two allocatable arrays, boxes and stres.  One of these types has a pointer to the other:
      module data_n
      type :: t_box
        integer                  :: num
      end type t_box
      type :: t_str
        integer                  :: num
        type(t_box), pointer     :: begin
        type(t_box), pointer     :: end
      end type t_str
      type :: t_stuff
        type(t_box), allocatable :: boxes(:)
        type(t_str), allocatable :: stres(:)
      end type t_stuff
      end module data_n
      program test
      use data_n
      implicit none
      type(t_stuff) :: foo
      allocate(foo%boxes(2))
      allocate(foo%stres(1))
      foo%stres(1)%begin => foo%boxes(1)
      foo%stres(1)%end   => foo%boxes(2)
      end
When I compile this I get:
bb.f90(31): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [FOO]
bb.f90(32): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [FOO]
If I put the TARGET specifier in the t_stuff definition it complains too:
bb.f90(15): error #6516: This attribute specification is not valid for a component definition statement.   [TARGET]
        type(t_box), allocatable, target :: boxes(:)
How do I do this properly?
Adrian_F_1
I replaced allocatable with pointer and it seems to work.  I hope that's the correct method.
mecej4
Specify "TARGET" on Line-26.
Caution: using both pointer and allocatable attributes for variables that interact with one another requires careful planning and execution.
