29487 Discussions
Can ifort handle unformatted files that are both big_endian and little_endian
crtierney42
I have received some data files that have been difficult to read. It turns out that the data in the file are little endian, but the Fortran record indicators are big_endian. I can't go back to the source and figure out what they were doing. I am pretty sure the files were generated on an IBM Power system under AIX (but I am not positive).
Is there a way to tell the compiler to read the record indicators as one endian type, but the data as another?
Craig
No, sorry. I'd be very curious to know the details of how such a file was constructed - I haven't run into such a combination before.
The best I can suggest is to write some routines to do the byte swapping after you read the data.
crtierney42
It came from an IBM Power system. I think that the data were generated by a C routine that mimicked creation of an unformatted fortran file. I found someone who wrote a code to do the conversion for this data.
