29386 Discussions
Can't Create a Fortran DLL independent of VS
Denny_Frost
I have created a fortran dll using Intel Visual Fortran in VS 2008. I run this dll from excel in a VBA macro. The macro runs fine on my computer, but as soon as I try to run it on other computers in the office, excel throws and error saying it can't find the .dll file. I checked the system log where it said that it failed to find a VS 2008 library during runtime. I would like to make the .dll independent of VS 2008, which I thought it would be already. Is there a compiler setting I missed in order to keep the .dll from using system libraries? Any help would be appreciated!
DavidWhite
Valued Contributor II
You need to link against static libraries when you build the DLL. So use the "Multithreaded" Runtime Library option under Fortran / Libraries.
Also, are you using an Excel Add-In in your Workbook to link to the DLL? If so, Excel puts a hidden path into your workbook which links to this Add-In. This path includes your userid, and so does not work on another computer or for another user. I have found it useful to put the Add-In into XLSTART instead of into the Add-Ins folder, as this does not demonstrate the same issue. I consider this a bug with the Excel Add-Ins system, but don't hold your breath for it to be fixed.
David
DavidWhite
David
Denny_Frost
The first suggestion seems to work, thanks a bunch!
Also, the dll is not an add-in. I'm just using the 'Lib' keyword to create a subroutine out of it.
