29381 Discussions
Can't access GetMenuInfo function from USER32.f90
Russell_G_
I'm using Intel Visual Fortran 2013, with MSVS 2010.  I want to access the GetMenuInfo function which is in the USER32.f90 library.
However I'm not able to access this function.   I've tried to create a minimal test case:
SUBROUTINE updatemenu(hWnd)
  USE IFWINTY
  USE USER32
IMPLICIT NONE
  INTEGER(HANDLE)  :: hWnd
  INTEGER(HANDLE)  :: ghMenu
  INTEGER(HANDLE)  :: submenu
  INTEGER(DWORD)   :: ignor
  TYPE(T_MENUINFO) :: minfo
  ghMenu  = GetMenu(hWnd)
  submenu = GetSubMenu(ghMenu, 1)
  ignor   = getMenuInfo(submenu, minfo)
END SUBROUTINE updatemenu
When I attempt to compile this, I get the following error:
error #6404: This name does not have a type, and must have an explicit type.   [GETMENUINFO]
What's going on here?
Because the source for USER32 has inappropriate conditionalization. This is being fixed. Use the attached file as a temporary solution - just add it to your project.
447614
