29413 Discussions
XE 2015 Getting Started Page always opens
DavidWhite
Valued Contributor II
How do I stop the Getting Started page from being loaded whenever I open VS?
Previously, changing the settings on Tools / Options / Startup would ensure that my last solution would reload in the same state as when I closed VS.  Now, the Getting Started page also displays every time, and nothing I have tried so far prevents it loading.
Any idea?
David
Kevin_D_Intel
Under the IPS XE 2015 release the getting started appears to be embedded into the short-cuts under the program group Start > All Programs > Intel Parallel Studio XE 2015 > Visual Studio integrations.
Here's one method I used to alter this. I created a copy of the shortcut (Use VS2013) on the desktop, then right-click to select Properties, and under the Shortcut tab in the Target field removed this /command option:
/command "View.WebBrowser ^"C:\Program Files (x86)\Common Files\Intel\Parallel Studio XE 2015\Documentation\en_US\professional_edition\welcomepage_studio_xe\get_started.html^""
After starting VS you can configure the start-up in the way you described under Tools > Options > Startup to load the last solution.
DavidWhite
Thanks, Kevin.
It would have been better in the installer if the documentation link to getting started was a separate link or even just a command used the first time after the install.  Adding it to the permanent link doesn't really make sense.
David
Kevin_D_Intel
There was a separate compiler specific Getting started shortcut in previous releases that's been replaced with what we noted now exists under IPS XE 2015. I do not know the real reason/motivation for this change but I make some inquiries and roll-up your feedback.
mecej4
This comment has been moved to its own thread
Kevin_D_Intel
I have not yet uncovered reasons for the change we noted here with IPS XE 2015 but I submitted a defect report (see internal tracking id below) to Development regarding it and noting that it overrides/breaks the Tools > Options > Startup functionality.
From my research it appears some alternatives exist for displaying the Getting Started page without impacting the user’s chosen Startup functionality or ability to customize that. I will keep you posted about what more I learn.
(Internal tracking id: DPD200362055)
DavidWhite
Ken,
I have jsut reinstalled the latest version onto a new computer, and this hard coded link in Start Programs which always opens Getting Started is still there!
Can we please have a link which just opens VS without anything extra?  the command should be (for VS2010 integration):
"C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\devenv.exe"
David
Kevin_D_Intel
Hi David,
I apologize for the ongoing behavior. Development has not made any decision regarding this behavior/setup. I pinged for a status update and reiterated a request for a solution that avoids it. I will keep you updated on any news I hear.
