29375 Discussions
Is this is bug? Error: Invalid signal or error
billpeace
Program Test
    implicit none
  INTEGER, PARAMETER :: dble = SELECTED_REAL_KIND(P=10,R=50)
  INTEGER, PARAMETER :: sngl = SELECTED_REAL_KIND(P=5)
  REAL (KIND = dble), ALLOCATABLE, DIMENSION(:), TARGET  ::  wk3 , wk10,rsb0
  REAL (KIND = dble), DIMENSION(:), POINTER :: cpmu,rhocp,rsn
   INTEGER  err
   INTEGER  mswk10,mswk3,mst,ncomp,mstart
   integer m221,mrrb,msn,m
    REAL (KIND=dble)::result11
      mswk10=20352600
      mswk3=70480200
      mst=6784000
      ncomp=2
      mstart=1
     ALLOCATE(wk10(mswk10),wk3 (mswk3 ), STAT = err )
     ALLOCATE (rsb0(mst*ncomp), STAT = err )
       rhocp    => wk10(1:mst)
       cpmu     => wk3(1:mst)
       rsn      => rsb0( mstart:mst*ncomp )
       m221=37
       mrrb=mst-200
       msn=0
       cpmu=10104414.9170140
       rsn=1.138435243319734D-003
       rhocp(m221:mrrb) = rhocp(m221:mrrb) + cpmu(m221:mrrb)*rsn(m221+msn:mrrb+msn)
       !DO m = m221, mrrb
       !    rhocp(m) = rhocp(m) + cpmu(m)*rsn(m+msn)
       !ENDDO
       !  DO m = m221, mrrb
       !ENDDO
       DO m = m221, mrrb
           result11 =result11+ rhocp(m)
       ENDDO
       write(*,*)result11
end program Test
when mst =67840 or 678400  the calculation is correct.
if  mst =678400  there was an error :Program Exception - stack overflow
But if I use gfortran compile and run, there was no error
mecej4
There is no bug here. Copying/assigning large array sections consumes stack space, for which provision must be made.
Your program runs correctly if you use either the /link /stack:0x4000000 option or the -heap-arrays:10000 option.
Les_Neilson
Valued Contributor II
A style comment: (In a small example such as this) it may not be totally necessary but I always have one Allocate statement per array.
And I always check the status. You have not checked the allocation status. It may be just a precaution but I think it is a good habit to develop.
Les
Don't bother using a number with -heap-arrays. It doesn't do anything useful. Just say -heap-arrays. If you are doing this in Visual Studio, though, you must put in 0 under Fortran > Optimization > Heap Arrays.
