Can't open ucrt.lib
Thomann__Gary
I have IVF19.0.281 and Visual Studio 2019.  Trying to get them to work together on a fortran/C++ mixed language program with no luck at all.  The C++ compiles but the fortran does not.  I used the fortran compiler alone to try to compile the fortran code; after the first obj file was made I get the message
LINK : fatal error LNK1104: cannot open file 'ucrt.lib'
The ucrt.lib is in the windows kits in 10\lib\10.0.18362.0\ucrt\x86\ucrt.lib..
The library file is dated 3/18/2019.  The compiler knows its there, it simply can't open it.  We have a bunch of fortran projects where we use the Intel fortran and all of them now fail with the same error.
Any  ideas?
MWind2
New Contributor III
This may help, but it may not be the solution to your problem:
https://software.intel.com/en-us/forums/intel-fortran-compiler/topic/820713
JohnNichols
Valued Contributor III
try copying the LINK : fatal error LNK1104: cannot open file 'ucrt.lib' file into your project directly -- I have had this problem before usually with wrong windows kits
usually it is a path error - same thng happens with DISLIN on reinstall sometimes
JohnNichols
also search on ucrt in forum - Steve gives a lot of useful information on this error in the forum
All i remember is it is pain till it goes away
MWind2
New Contributor III
This is what I used (pre-link event) to find possible problems:
// environs.cpp : main project file.
#include "stdafx.h"
using namespace System;
using namespace System::IO;
using namespace System::Collections;
int main(array<System::String ^> ^args){
	String ^ sEnv = "Env" + DateTime::Now.ToString("yyyyMMdd_HHmmss")+".txt";
	StreamWriter ^ SWEnv = gcnew StreamWriter(sEnv);
	for each (DictionaryEntry de in Environment::GetEnvironmentVariables()){
		   SWEnv->WriteLine("  {0} = {1}", de.Key, de.Value);
    SWEnv->Close();
    return 0;
MWind2
New Contributor III
The attached is sorted environment code.
