29657 Discussions
Cannot access forum when using a VPN
andrew_4619
In recent days I get this error which goes away if I disable my VPN. Is this intended behaviour?
Steve_Lionel
It's not any VPN, as I can still sign into the forum on a VPN. But it would not astonish me if CloudFront, which Intel is apparently using here, has a list of VPNs it doesn't like. I've seen this on a few other sites.
andrew_4619
Indeed I am using a legitimate, reputable, and highly-rated VPN service that is rather well known! I will dig a bit on google
andrew_4619
Having looked at this is seems CloudFront clobbers a whole range of VPN stuff using pretty arbitrary  criteria. If I want to access the forum I have to bypass the VPN or maybe start messing with obfuscation.
GVautier
New Contributor III
Hi
I have the same issue with my internet provider address range. In my case, using a vpn solve the problem.
GVautier
New Contributor III
GVautier
New Contributor III
Hi
It seems that the AWS ip filter has been updated. I can again connect to the intel web sites.
GVautier
New Contributor III
Error, it works only randomly. May be the filter is deactivated sometime.
andrew_4619
Well it has not been working for me but today it works!
DavidWhite
Valued Contributor II
Not exactly the same problem - I now cannot log into the forum from my work computer - I can get to the login page, and using 1Password complete my credentials, but Intel rejects it as unknown user or invalid password.
On my own compter on the same network, using the same 1Password credentials, I can log straight in.
I was thinking that it was something to do with the URL protection at work, but that I can get to the login page seems to refute that.
andrew_4619
still working OK for me for several days now. The site mechanics seem to change on a regular basis , rarely for the better from a user perspective,
