29487 Discussions
Cannot disable warnings promoted to error with new Intel Fortran versions
bbu
with older Fortran compiler versions (at least up to ifort 2021.6.0 from oneAPI 2022.1) I was able to use the command line
   ifort simple.f -stand f18 -diag-error warn,remark -diag-disable 7373,10448
with simple.f a minimal fixed format source file
      program Hello
      print *,'Hello world'
      end program
sucessfully without any error message.
Newer ifort (and ifx) versions (ifort 2021.13.1 from oneAPI 2024.2.1, ifx 2024.2.1 and ifx 2025.1.1) now complain:
   Cannot disable Fortran error message 7373
   simple.f(1): error #7373: Fixed form source is an obsolescent feature in Fortran 2018.
   program Hello
   compilation aborted for simple.f (code 1)
But without "-diag-error warn,remark" it is working without any error message.
Actually I'm using much more -diag-disable with -stand f18, but this was the easiest example. I'd like to keep the other warnings promoted as errors, especially the many warnings introduced with -stand f18. Is this no longer possible with Intel Fortran or do I have to use different options?
